need help to install a tachometer
hey, i have a 2002 civic si,( canadian) and i just got a tachometer and i wanted to now how to install it as effecient and clean as possible.......... thanks.......
If anyone could help just message
there should be a blue wire by itself next to the battery with a black connecter on it. that will b your rpm signal than all u need is power (switched) and ground. oh and a good place to mount it!! good luck
see if this helps
http://www.7thgencivic.com/modules.p...howpage&pid=20
Originally posted by speedcreations
I used that wire but my tach is always off...
It either reads way to high or not enough.....
ok i have a pic of where the blue tach wire is and a pic of what i mean by code on tach is a little blury but you can still see it. the tach should have a green wire coming out now thats the one that you connect to the blue one thats by the battery and also the power cable should be on in order for it to work atleast mine does
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
