JL Audio 250.1 & 2 12" Polk GXR Subs CHEAP
Old Apr 19, 2004
keepin_it_clean's Avatar
keepin_it_clean is an unknown quantity at this point
Aight guys, I need to get rid of this amp and pair of subs...All of this stuff is in Good condition.....Buyer pays all shipping costs...and I do not want to ship the box, pickup only on the box itself....Retail on this jl amp is over $325, I'm asking $200 plus shipping....
Specs....MonoBlock Amplifier Rated Power: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V) THD at Rated Power: <0.05% @ 4 ohm S/N Ratio*: >95dB below rated power Frequency Response: 5 Hz - 500 Hz (+0, -1dB) Damping Factor: >500 @ 4 ohm/50 Hz Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions: 10.25"L x 9.25"W x 2.36"H Features: Differential-Balanced Input Topology: (1 pair of inputs) On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave) Preamp Output: 2-channel (full-range, LP or HP) Bass EQ: variable boost up to 15dB Infrasonic Filter: defeatable 24dB/octave at 30 Hz Signal-Sensing Turn-On: permits operation without remote lead Dual mono speaker output connections: accept up to 8ga. wire +12V and Ground connections: accept up to 4ga.
The subs are 2 12" Polk Audio GXR124's with dual 12" gray carpeted box, Asking $70 plus shipping for the two subs...
Old Apr 19, 2004
hustlelikem0fo's Avatar
My 50 Watt Jensen amp will blow the JL amp away
Old Apr 19, 2004
amp is sold for $150
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
sf3r8z
Sep 23, 2015 03:26 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
