Setting the timing?
Old Apr 17, 2004
MadWheel's Avatar
Premium Boosted Member
Setting the timing?
Pulling the head off my car tomorrow... Any tips on setting the crank and cam shafts to TDC? use a breaker bar? I already have the torque specs and the valve cover is off...
Thanks guys
Old Apr 17, 2004
I believe the best way is to mark everything before starting, so you can put it back the right way again.
Old Apr 17, 2004
MadWheel's Avatar
Kinda knew that... lol..
But for rotating the crank shaft pulley... I have no clue how to do that. I can do almost anything else to an engine but I just dont grasp the timing thing well lol.
Any help would be appreciated.
Old Apr 17, 2004
VTECnique's Avatar
VTECnique is an unknown quantity at this point
use a socket, long extension, and a breaker bar thru the drivers wheel well. you dont even have to take the tire off. just cut the wheel to the left.
Old Apr 17, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Here is what I did. Maybe right or wrong it worked.
Pull the head. Turn the crankpulley untill you are TDC that is the outside pistons all the way up. Then tunr the cam gear to the top position. The came gear has a leg that says up on it. then get a buddy and about 4 flathead screw drivers and carefully pry the belt back into place. You could also set it to TDC first and mark everything and then put it back in place using the marks.
Good luck. Mine is holding good and have some good new kills.
Kills: B18 all motor Hatch, MustangGT and a Mercedes(?).
Old Apr 17, 2004
opto_isolator's Avatar
Re: Setting the timing?
Thanks guys
Yes, buy a damn Helms manual! Christ, everyone spends thousands on parts, but neglect the bible fo the car...It has everything you need to repair the D17.....Man....
Old Apr 17, 2004
MadWheel's Avatar
They said they couldn't get a Helms manual for my car buddy, so I COULDN'T buy one.
I did however spend $99 on the Honda Repair manual straight through the dealership. It takes a week and a half to come in though, and I don't have enough time to wait that long.
jbradley4809
Apr 7, 2017 04:23 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
SpoonSportsd17a
Nov 19, 2001 09:26 AM
silvercallx
Aug 19, 2001 12:36 AM
