Spark Plugs, WTF
Spark Plugs, WTF
so i hit 40000km yesterday (24854 miles), and the weather was amazing today, so i decided to change my spark plugs to Bosch Platinium. easy job, but the Stock Sparks are sooo rusted. Is this normal for only 40 000 ? i mean the dealership only says to change them every 80 000km. so is it my driving or is it that the OEM plugs are crap ?
i changed my plugs 2 weeks ago for the first time since i'v had it and my car has 50k on it,they looked just like that too i also got the bosch plugs as well and it made a nice differance.next time i will get the iridiums when i can spend 50 bucks on plugs
dont get bosch, car idling is very bad because they are a i think a european company, and your putting them in an import car? doesnt make sense does it? My vibrations went away as soon as I changed to denso iridiums. OMG so much better.
Re: Spark Plugs, WTF
yooooooooooooooooo
DID you experience a gain in your gas mileage????
i need that info, dudeeeeeeeeee
cos' im gonna change my stock plugs with NGK iridium IX!!!
currently, im 25K miles...Im gonna change it on 27K miles...
freak, i only got 300+ miles for every 12 gallon...it's suppose to be 400+ @#$%!
Re: Re: Spark Plugs, WTF
Originally posted by opto_isolator
Dude, look a the tips. Those look burnt - as in either your car was running too lean, or your running too hot of a plug.....maybe try one grade cooler plug.
as for milege, i wouldnt know, i juts did this today, but my Idle RPM are a bit lower know and the car is quiter at idle
Bad plugs can reduce gas mileage. Mine were bad at 18K, all black. I suspect the car is running rich because of all the carbon. Good thing I'm getting it tuned soon.
Buy Denso IK20s from Dezod at Dezod.com. Or can PM him. Tell him madwheel sent you. He'll hook you up, one of the best sellers on this site.
Spark plug analysis. This should help determine why the plug is fouling.
http://www.gnttype.org/techarea/engine/plugs.html
Re: Re: Re: Spark Plugs, WTF
can you explain this a bit more, my car is all stock engine wise, so whatd do u mean too lean or too hot.
Also, the plugs have had a good amount of time to sit in that aluminum head. and aluminum rusts
. So here is was you should do. Ask for some spark plug compound that helps it resist in rusting, that way it is easier to pull next time.
. So here is was you should do. Ask for some spark plug compound that helps it resist in rusting, that way it is easier to pull next time. Turbos, Engines, Chassis and Suspension Tech
Those spark plugs look fine. They looked burned, because they are. Why? Its in the combustion chamber. Duh. What happens in a combustion chamber? Fire. If the car is lean, it will be a lighter shade of brown. Rich, darker black. speckled usually means detonation. Also a statement like: "dont buy bosch, theyre a european company, and putting that in an import car is bad" is completely and utterly retarded. If its a european company, wouldnt that have to be imported too?! just like a BMW is an import. Its a european import not a japanese import. Since when have only asian cars been considered imports? And generally "Rust" as its called, is oxidized Iron (III). Also known as iron oxide. Aluminum oxide is not generally called rust in any sense of the term. Granted it is a similar chemical reaction. http://news-service.stanford.edu/new...minum-517.html has some good info about it.
hmmmmmm please read the following maybe i cant read .....
http://www.cogsci.princeton.edu/cgi-...ge=1&word=rust
Overview for "rust"
The noun "rust" has 4 senses in WordNet.
1. rust -- (a red or brown oxide coating on iron or steel caused by the action of oxygen and moisture)
2. rust -- (a reddish-brown discoloration of leaves and stems caused by a rust fungus)
3. rust, rusting -- (the formation of reddish-brown ferric oxides on iron by low-temperature oxidation in the presence of water)
4. rust, rust fungus -- (any of various fungi causing rust disease in plants)
