40 PSI on my 04 from the factory!!!
Old Apr 10, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
The door tag says 30! how could they make that mistake?
Old Apr 10, 2004
CapYoda's Avatar
Escaped Convict
people always over torque, over inflated. etc. etc.
although, did u measure it when its cold? heh. ie: not driven for at least 3 hours.. cuz the measurement would be off then.
Old Apr 10, 2004
dirtySAMURAI's Avatar
I log in from time to time
oh buddy...at first i thought you were talking about a turbo there.....wow...40 psi..that would be insane...
Old Apr 10, 2004
Mr.Modify's Avatar
^^^^^^LMAO
Old Apr 10, 2004
Yeah, make sure the car sits overnight before measuring. Then put them all back to 30.
Old Apr 10, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
dont feel bad infinite012 i thought the same.
Old Apr 10, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
wow..i never checked that b4..
Old Apr 10, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
don't feel bad.. that's why i checked this one out too.
Old Apr 11, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Same here... ha
Old Apr 11, 2004
mhr's Avatar
mhr
mhr is an unknown quantity at this point
on the tires then?
Old Apr 12, 2004
crv16's Avatar
crv16 is an unknown quantity at this point
Re: 40 PSI on my 04 from the factory!!!
Honda does that with all vehicles they make. They do that to prevent flat spotting - because the car might sit for several weeks or months. The dealer is supposed to deflate the tires to the proper PSI prior to delivery. They obviously didn't do that with yours.
Old Apr 12, 2004
civic01vtec's Avatar
LOL......me too
Old Apr 13, 2004
mhr's Avatar
mhr
i better check mine!
Old Apr 14, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
after the dealer rotated my tires, i changed them about a week later and some lugs were over tightened while some were way undertightened...
how did this happen? aren't dealers supposed to use torque wrenches?
Old Apr 18, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
Heh, I'd deflate 'em down to 30 or 32. I've not checked mine, but they appear to have the proper amount of sidewall bulge for a radial... maybe I'll do that tonight.
To a certain point, tire inflation is a matter of driving style. The tires will perform the best when they are properly inflated.
Here's a quick, easy and illegal test of proper tire inflation:
1.) Measure the tread-width of your tire's contact patch.
2.) Burn out like a maniac.
3.) Measure the width of the rubber left behind.
If the burnout is wider than the contact patch, you're under-inflated.
If it's narrower, you're over-inflated.
Old Apr 19, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
Dealers don't use torque wrenches. It takes too much time. They would either use a torque stick (if the tech had one) or just use their impact gun and tighten by feel.
I hope u used a torque wrench to tighten them.
Old Apr 20, 2004
nivenmk1's Avatar
Technically speaking, the dealership *should* have their impact wrenches set to a specific torque value... Unfortunate that so many do not... Thats why I've got my own (torque wrench, not dealership)
Old Apr 20, 2004
GreenNVicious's Avatar
Newbie
I know, i was like WTF
Old Apr 20, 2004
redvtec04's Avatar
VTEC MASTER
torque stix. They are a socket extension and are different thicknesses for different torque settings. No matter how much they air hammer with one on it wont torque more than the stix rating. wierd.
Old Apr 23, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
Re: Re: 40 PSI on my 04 from the factory!!!
actually, the tires are overinflated for shipping purposes. once the car arrives at the dealership, it is supposed to be sent to the pre-delivery inspection department. (PDI) the PDI department checks the tire pressure, "tops off" all the fluids in the car, fills it with gas, and makes sure everything works. it sounds like your dealers PDI department was slacking...
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
NROD315
Sep 12, 2015 02:46 PM
