01civic wont start.
Old Apr 5, 2004
ophion's Avatar
ophion is an unknown quantity at this point
01civic wont start.
The battery and oil light is on with key at START II position. When I turn the ignition, everything sounds normal except the engine will not turn over. Any idea what might be wrong?
thanks,
ophion.
Old Apr 5, 2004
flotsamm's Avatar
Dead battery? Do your headlights turn on and if they do, are they bright or faint? If bright then you should have enough juice to start up. If not then it could be your battery.
Old Apr 5, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Have your battery checked by a shop. By your description, sounds like your battery doesn't have enough juice to crank the motor.
Old Apr 5, 2004
ophion's Avatar
I'll check the battery when I get home. Maybe my sis left the lights on over night...cross my fingers.
thanks,
ophion
Old Apr 5, 2004
ophion's Avatar
Finally got the engine started...and had no problems getting it started after that. I asked my sister what she last did to the car and she tells me she just moved the car, sitting in the driveway for over 5 hours, back into the garage around 7pm. The temperature dropped quite a bit in Toronto last night and this morning. My sister's quick trip probably cause moisture to form inside the engine, and freezing on some sensor over the course of the night, causing the engine not to start up. I hope that's what happened. Anyways, thanks for the help.
-ophion
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
bowie
Jan 21, 2018 09:29 PM
2.0.0.2
Sep 14, 2015 06:38 PM
xorex83
Sep 8, 2015 08:07 PM
NROD315
Sep 4, 2015 09:22 PM
