Serious info--torque specs!!
Okay people, I went out last night and got one of those $20 torque wrenches from Sears to check how good my spark plugs and neuspeed bar were tightened.
The neuspeed bar was pretty close, and maybe a little too tight. Spark plugs were almost loose! Not tightened well at all! It showed maybe a few ft/lbs instead of the 14 it says in the manual. You guys absolutely need a torque wrench when installing stuff like plugs, header, and strut bar type stuff. Please go get one, as $20 is nothing compared to repair costs from your car. I hope my engine didn't get damaged, cause it was like that for a while.
actually if the $20 wrench hes refurring to is the old beam and pointer style. They tend to be more reliable then the spin the handle to the desired torque type. Granted the newer style is by FAR easier to use!
Yeah, I got the pointer and beam. It's a little bulky but does the job. I had one with the spinning bottom and couldn't figure out how to set it right.
If you go the harbor freight, you can get the spinning bottom for about $20. I got one and its really nice. I think this is easier to use than the other one.
Why couldnt you figure out how to work it? On the spinner, there are #'s 0 2 4 6 8. On the handle there are also #'s 0 10 20 30........ (you get the idea). If you want to torque 86 ft/lbs, you would loosen the bottom to get the spinner loose. Then you would spin the piece to the line (-) where 80 ft/lbs on the 0 mark. Then you would spin to the 8 is even with the center line down the middle of the bar. Now your at 86 ft/lbs.
Someone should do a "DIY" on using the two different torque wrenches. I just got my first use of the spinning style when I swapped my motor out. It's not hard to use but I had someone show me which made it much easier.
yeah, somebody should make a DIY for torque wrench...it confuses me...
anyway, gearbox, r u planning to sell ur car and get the '04 or '05 civic?
based from ur car's description.....rattles, mpg sucks, etc?
Originally posted by Green Civic
If I can get a hold of a digital camera, I can write one. I only have the spin style. I'll see what I can do.
at Home Depo, u can get one Husky made torque wrech for about $50.....10~150 lbs......very good product
u defin. needed one of these for changin ur spark plug, if overtighed, thats going damage ur motor
Originally posted by Civicious
I have snapped many bolts without one.
but they sure are expensive....
the funniest part to play with? i think it's t he plastic clips on the front bumpers...LOL
front bumper removal looks hard....IMO it's actually easy. damn.
Originally posted by zen_master
luckily...replacements are available at ur service from the dealer and majestic...
I haven't taken the front bumper off yet. I removed the rear one though. It virtualy snaps into place.
The most challenging thing I've done on this car besides my engine swap (d17 to d17 nothing exciting) was the passesnger front hub. You have to take the complete wheel assessmbly of the car out and beat the hell out of it with a mallet to get it out.
Whoa, digital. That would be nice, but I don't use mine alot anyway. The pointer style is cool, just a bit bulky.
No, I'm keeping my car forever hopefully. Just has problems like any other car. I'm working on making it faster now that the exterior and interior are pretty good. My mpg is up to 25 now, and I really want it to stay that way. It's better than before, and that hyper boltage system really helped out.
The nice part about the pointer style is calibration consist of you flexing/bending the pointer to zero with no torque applied to the wrench. The spinning handle types are much more user friendly thou. Down side of the spinenr is you dont really know when and if its out of calibration. well at least the tool used to check calbration used to cost in the $1000's as i recall? My gray hairs are overwhelming my brain at the momment
Zygrene
Mar 22, 2016 12:36 PM
Islesfan
Sep 29, 2015 03:42 AM
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
Touge
Sep 1, 2015 11:25 PM
It rules a lil over kill but still worth the money.
