17" rims
Old Mar 23, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Question 17" rims
Hi,
I am looking into throwing some 17's on my car and maybe dropping it 2 inches. Has anyone done this. If so what shocks do you recomend and also would a camber kit be required. Any info would be great. Thanks
Old Mar 23, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
Of course someone did this before, you will need new shocks because it will go out eventually, and spc camber will do. try searching next time.
Old Mar 23, 2004
Htowncivic's Avatar
Htowncivic is an unknown quantity at this point
I have that setup on my car...you don't need shocks, I still have my stock ones, but if you want them get Koni yellows. You'll be ok w/ no camber kit, but I recomend at least a rear camber kit and I like and have SPC.I've had this setup now for 2 years and it's worked for me.
Old Mar 23, 2004
L23Tan's Avatar
L23Tan is an unknown quantity at this point
For shocks... the best would be Koni's.
If you want, u can also go with FULL Coilovers... something like Tein SS or KW or JIC... but that's gonna cost a lot more. That way, u can adjust ur height as much as you want.
As for camber kit... yes, if u go that low, it would be best to get a camber kit, assuming u're gonna be riding on 17's... just so u can save the wear on ur tires... especially the rears! the fronts might be okay! just make sure u get an alignment done, so u know for sure!
hope that helps a little.
Old Mar 23, 2004
robbclark1's Avatar
Retired suspension supermod.
Please Read the suspension FAQ, look at the Dropped Pics post above for ideas and search.
Old Mar 23, 2004
pbfoot's Avatar
get hayame coilovers if youre on a budget, or tien or jic if you can afford them. Tanabe makes nice ones too i heard...also pricy tho. unless you just want for show, dont waste your money on springs/shocks. its a pain in the a$$ and the combo will cost you as much as hayame coilovers anyway.
17" is ok, it looks good, but the ride is a bit rough. depends on the roads you have there. i doubt ill buy 17s again with this size car. id go +1 from the largest size that comes off the factory.
you should get a camber if youre doing a 2" drop. ingalls or spc will work fine.
next time search....or at least browse the forums a bit.
Old Mar 23, 2004
cryption's Avatar
2003 Nissan Frontier
i ahve 17" rims and a good sized drop .... i love my Tien coilovers ... and i used the Goldline (spc) camber kit and am super happy with the ride and performance.
right now im looking into sway bars and hoping for some help from my homies on the forums
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
