Civic Si (Canada SIR) swap of seats
Old Mar 20, 2004
Smokeman909's Avatar
Smokeman909 is an unknown quantity at this point
Hi, the search does not let me type Civic Si Seats so I will ask my question, even if I know this is not the first time the question is asked.
Can I swap in my 2003 civic ex coupe (canada civic Si) the front seats of the 2003 civic si (canada sir)?
Same question for leather seats from acura 1.7EL or acura RSX?
thanks
Old Mar 20, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Yes you can, for all the models you mentioned
Old Mar 22, 2004
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
yes, but on some of the seats (depending on vehicle) 3 of the 4 bolts will line up perfectly, while the fourth will not. Either you can modify it or just go with 3 bolts holding the seats.
Old Mar 22, 2004
cryption's Avatar
2003 Nissan Frontier
its easy to modify though ... for my seats none of them lines up so we welded entirely new brackets
Old Mar 22, 2004
TeLLy's Avatar
Yes, it's an Acura EL
The 1.7EL seats would swap in perfectly.
Old Mar 23, 2004
thanks
thanks for the info
Old Mar 23, 2004
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
Yep, that would probably be your best bet. If you have a sedan, it would be even better, you could swap the front and rear leather seats into your car. You may even be able to hook the heated front seats up somehow if you get the wiring and buttons for the dash, etc...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
El_Spic
Apr 23, 2015 03:14 PM
MooCoW
Nov 9, 2001 05:22 PM
weber
Nov 5, 2001 05:19 PM
