Redline limits
Old Mar 6, 2004
ceebozz's Avatar
ceebozz is an unknown quantity at this point
Redline limits
Greetings,
I think the redline limit is around 65oo for my 01 civic..
What is redline on the DOHC older engines..?and on the si model?
Just curious..
thanks,C
Old Mar 6, 2004
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
we redline at 6800.. but can go up to 7000 - 7200. i believe the redline on the dohc were at least 8.
Old Mar 6, 2004
dre2600's Avatar
I was under the impression that the redline was 7200rpm in our cars? I do recall hitting the rev limiter once by accident and it being above 7k.
Old Mar 6, 2004
abmerop18's Avatar
Jam out with your clam out.
rev limiter is exactly 7k redline is 6800
Old Mar 6, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Current Si model same... (6800 redline)
DOHC on RSX-S is 8000
Old Mar 7, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
Oh, what I would do to extend my red-line ever so slightly...I would be able to get the full potential out of my re-grind...only thing is that it costs $$$ that I don't have...
Old Mar 7, 2004
abmerop18's Avatar
as stated 100 times before, you will not gain power by increasing your redline, peak HP is around 6200-6300 RPM and you HP all after that
Old Mar 7, 2004
Umm.... Honda put the redline there for a reason.
Unless you remap your ECU, and do some engine work, there is no point. You'll only end up running slower times, plus hurt your engine.
Old Mar 7, 2004
Hypnotik's Avatar
Hypnotik is an unknown quantity at this point
its true that you will not gain any HP (peak HP IS reached around 6200-6300) by increasing the redline, but the reason for revving past the redline is so that you can reliably land in vtec when you upshift. its not nearly as helpful as keeping it in lift for celicas, but might still help. although, you do run the risk of messing up your engine, and it you want to do this in an LX or DX then you're just an idiot :P
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 3, 2015 04:33 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
carid
Sep 28, 2015 10:13 AM
