Check this $hit out!
Old Mar 6, 2004
opto_isolator's Avatar
Smile Check this $hit out!
Almost done with everything. This is just a test fit. The upper IC pipe is a smigen short, but it will work (T-Bolt clamp). I don't think right now I'm going to powder coat anything - I just want to get this done. Can't finish the project until I get my new manifold (and some way to install larger injectors)....
Shot 2:
Oh yeah, where to put the windshield washer bottle too...:
Old Mar 6, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
nice
Old Mar 6, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
And so it begins.....
Old Mar 6, 2004
Heh, yeah - it was a Saturday, I had some time to kill. Figured I'd try and start putting things together. Of course the fun part is that I have to take them all apart (since I need to be able to drive my car). So I'm almost there....Hope to be able to run around 6 psi with the emanage alone....Hopefully the injector fiasco will be solved sometime this year!
Old Mar 6, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Who made the piping? Love that Spearco FMIC.
Old Mar 6, 2004
BoostedCivicZex's Avatar
Proud Srt4 owner
lookin good
Old Mar 6, 2004
zinkyroo's Avatar
cool beans
I think he made the piping and took it to a welder or he did it all himself
Old Mar 6, 2004
Yeah, I ordered 2.5" SS from the net (mandrel bent of course). With the help of a lot of masking tape I lined everything up. Once I had it I brought it to a cool shop in in Orlando and had him weld it.....He did a good job!
Old Mar 6, 2004
Proud Srt4 owner
^props on the piping, anyways, where are you going to put your bov?
Old Mar 6, 2004
BOV? Oh $hit!!!!
J/K -
Look closely at the secondt photo. If you look right up from the power steering resevoir you'll see (barely) the flange for the SSQV. I didn't put it on at the moment because I was just fitting the piping up. I wanted to place it closer, but space was limited with the route I went.....
Old Mar 6, 2004
tfnaaf's Avatar
BLDNPSI Mod
Looking good Opto, keep us posted !
Old Mar 6, 2004
Proud Srt4 owner
^oh ok lol
Old Mar 6, 2004
civicskater's Avatar
Chicks dig my scent
do you have an LX or EX? I have an LX, and need to find which side of the engine bay to take the charge pipe...looks good though man...
What did you remove from the engine bay to get it to fit?
Old Mar 6, 2004
MadWheel's Avatar
Premium Boosted Member
It's prob an LX (possibly a DX)... there's no vtec logo on the spark plug cover...
From what I could see, all he removed was the full stock air intake assembly, possibly his air conditioning system.
Old Mar 6, 2004
Actually, the only thing I removed was the stock intake filter / airbox, windshield washer bottle, and horn (I had an airhorn installed).....Of course I still need to find a place to mount the horn and washer bottle....Its an LX BTW.
Old Mar 6, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i just ditched the washer bottle on mine, i wish i could get more info for u on the injectors, but im a long way from the shop and the car, i will take picts on friday the 12th, and post them the 14th evening
Old Mar 7, 2004
Chicks dig my scent
nice, is there any way to take the charge pipe from the left side up the intercooler to the throttle body on an LX? Or would you have to relocate the battery and all that also?
Old Mar 7, 2004
To be honest you can do whatever you want. The only thing is you need an intercooler which has an entry / exit on both sides (SF's kit does this). I went this way because I wanted a spearco intercooler (bar and plate - better cooling capacity), plus there isn't as much of a pressure drop due to changes in direction.
Old Mar 7, 2004
civic01vtec's Avatar
that FMIC is sexy !!!
props on the piping and i bet they would look great powdercoated.
Can't wait until it is finally done
Old Mar 7, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Yeah... I had to ditch the windshield washer. But I figured how to "remount" one. Take's a little DIY work though and you have to lengthen the wires. The downside being that you have to fill it up with a funnel, upside being that you don't need to remove the bumper to refill each time. I guess it all depends on where you live as to whether or not you need the resevoir. I know I needed it.
Looks good so far though... can't wait to see it finished. Good luck.
Old Mar 7, 2004
Really? Where did you end up finally mounting it that didn't require removing the bumper?
Old Mar 7, 2004
Boosted2k2's Avatar
I never did the final mount... I fitted it, but never had time to do the actual install. But you can fit it on the other side of the bumper. But you have to cut part of the neck off the reservoir, replace the cap (or a cap) on it, drill a hole through the cap, and run a rubber hose in it and up to the engine compartment and get a bracket to keep it in place. The hose was pretty unnoticeable. Then just fill it up with a funnel through there. I guess if you even wanted, you could place a dipstick to check the level. Like I said though... it's DIY, so don't expect it to bolt into place. There was enough room for it above the IC piping, and it could have been snug on top of the IC piping, and warapped pretty tight on cars frame (where the piping makes a 90 degree turn) with metal wire. Then, just extend the wires over to that side of the car (easy) and run some more washer tubing to meet up with the end on the other side of the bumper.
Some could call it ghetto rigged, but it would work pretty well. The only other option I can think of is rerouting the whole thing to the trunk lol. Cuz there sure as hell isn't any room in the engine compartment.
dinsum
May 28, 2015 09:30 PM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
