Need an Exhaust for 2001 HX 2door that is bolt on, NO WELDING
Old Feb 20, 2004
BigD's Avatar
BigD is an unknown quantity at this point
Trying to buy a used one has become impossible. Therefore I am going to buy new. I want something not too expensive that can install by bolt-on, no welding required. I have a 2001 Civic HX. I really like HKS's titanium exhaust, but I do not think that it works for my car. I don't need a full exhaust, partial is fine. Most importantly I don't want to screw with the car's warranty, so I need to be able to remove the exhaust if something happens with the car. Pro Car Parts has an HKS hi-power system for 305.24 plus shipping and tax, is that a good deal and will it fit without welding? What else would be a good idea? thanks for all your imputs.
Old Feb 20, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
well in that case you ever thought about just the axle back its not to pricey, and as for the HKS for 305 not bad about the fitment well hopefully its not for the ex then it wouldnt fit, HX that might be diffrent from the dx\lx correct me if im wrong tho, go for a axle back,
Old Feb 21, 2004
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Yeah I think the best your going to find for that would be an axle back setup as well as it would be easy to remove if needed.
Crashoveride
Old Feb 22, 2004
PJG's Avatar
PJG
PJG is an unknown quantity at this point
I love my HKS Hi-power. Get it from Robearracing.com You might end up spending a little more, but if anything happens to the exhaust. Robear will be there to help you out. To give you an idea of how long it took to put on, it took my friends and I more time to put the car up on the lift, then to switch the exhaust systems. It was super easy with only two bolts to unscrew, and screw. You won't regret buying this product. Such a high quality exhaust.
Old Feb 22, 2004
Well, I would have told you to get the Thermal rear, but it's discontinued. HKS is still very good, and it's an axle-back (just bolts right in).
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
LionSpratt
Jan 29, 2017 11:07 PM
old97civic
Jul 9, 2015 12:19 PM
PierrePierre
Jun 17, 2015 06:22 PM
supercivic01
South
Nov 30, 2001 11:27 AM
