Trace of gasoline smell from the oil...
Old Jan 31, 2004
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
Hey guys..i've got a problem..everytime I check the oil...I smell gasoline from the oil..do you guys know what is contributing to this.and..would this type of problem be covered under warranty..? I usually check the dipstick..wipe the oil on a napkin..and sniff..and it always smells like fuel..even tho I jus recently changed the oil..the smell still remains....anyone know what this could be from...? and what should I tell Honda in the best way..
Old Jan 31, 2004
I'm no expert, but that sounds very bad. Maybe the seals are bad or something. Have that checked under warrenty ASAP!
Old Jan 31, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
That's not right! But of course Honda will try to tell you that it's "normal"
Old Feb 4, 2004
what other problems are contributing to this...cuz i wanna go to Honda and claim there's "this" problem..cuz if i go in saying my oil is smelling like gas...in my opinion.they wont' do anything..they'll probably say this or that..can anyone help..?
Old Feb 4, 2004
tfnaaf's Avatar
BLDNPSI Mod
Is the car running fine? Is it hard to start?Typically your describing a over rich condition and can be harmful to the engine over time. If there isnt a over rich condition then it may be fine. It is possible to have a small amout of fuel odor coming from the oil.
Old Feb 6, 2004
Originally posted by tfnaaf
[. It is possible to have a small amout of fuel odor coming from the oil. [/B]
So it IS possible to have a small amount of fuel odor.....what can be causing this..do u know..?
Old Feb 6, 2004
tfnaaf's Avatar
BLDNPSI Mod
Does the car start hard? when it does start is there a puff of black smoke?
Old Feb 8, 2004
No it starts fine..performance is "ok" i guess....no puff smoke...jus that my oil smells like gas...not too much.but it's noticeable..
Old Feb 8, 2004
Da1lyDr1ver's Avatar
sounds normal i smell a little of gas too when doing oil changes.
Old Feb 8, 2004
modoman's Avatar
sounds like a seal somewhere... possibly* a piston ring.. but i dunno cuz i dont think ive sniffed the oil the last few times i changed it
Old Feb 9, 2004
Mbow's Avatar
I agree, of course the oil is going to smell like gas. Not like a gas can or anything but you definately be able to detect a gasoline smell. I think you are experiencing the normal smell of used oil.
Old Feb 11, 2004
what do you mean by "hard start".... by the way...the oil level seems higher too...and it got darker quicker even tho i jus recently changed my oil.....I think I need to take it to Honda...if they do a diagnosis it tells them everything..rite? this is becoming a greater problem...
Old Feb 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
It's possible from what your desrcibbing is that maybe an injector is leaking and when you shut off your car it basically bleeds off all the fuel pressure in to the cylinder causing it to be hard to start, and also the fule could be washing down the cylinder walls intot eh crank case. This is all guessing but a possibility i think.
Old Feb 12, 2004
actually it starts..normal I guess...I could also hear a high pitch whistle sound when i accelerate..could that be due to gas in my oil..?
cferry7
Oct 3, 2015 04:33 PM
Luluharp
Sep 27, 2015 11:56 AM
tropicola
Sep 25, 2015 07:02 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
