Sponsored by:
Sponsored by: CARiD
red honda emblem from hondawerx.com
Old Jan 31, 2004
slamtank's Avatar
slamtank is an unknown quantity at this point
i bought red honda emblem from hondawerx.com
hondawerx says its from JDM EP3
i asked greg about it and he said it would fit to 7thgen civic coupe
so i bought it
but i found that this red H is bigger than the original H of my car when i got it
theres two things on back of the emblem
(i dont kno how to call it..its something like pins..it (i guess) goes into the holes on trunk lid and hold the emblem there)
i dont kno if these fits to my coupe
but just seeing the size of the emblem, this red one is bigger than stock one.
let me know if it will fit to my car if someone has an experience.
i got it from hondawerx.com and they said its from JDM EP3
if anyone had bought same thing let me know if it fits to coupe
Old Jan 31, 2004
robbclark1's Avatar
Retired suspension supermod.
did you test fit to see if the pins will fit? Sometimes the emblems are larger but they will still fit.
Old Jan 31, 2004
RedDragon333's Avatar
are the pins on the emblem to big to fit or is the emblem literally too big to fit. because you could always pull the pics off and get some 3m tape and put it on that way unless you want to drill more holes.
Old Jan 31, 2004
egot2da4th's Avatar
egot2da4th is an unknown quantity at this point
yeah i had the same poblem...since the pins were spaced differently what i did was file them down so it'll be flat....then it fit
Old Jan 31, 2004
slamtank's Avatar
i got 03 and i posted this cuz i havent shaved the original one, so i couldnt figure out if the pins fit..
seems even the pins wont fit..right??
hm..he said it will fit..
if i use 3m tape wouldnt that make a gap between the emblem and trunk??
Old Jan 31, 2004
egot2da4th's Avatar
yeah mine had the adhesive on the back....
there's no probs ...it fit pretty good....no gap or anything
Old Jan 31, 2004
dalaw's Avatar
Bone Stock!
Hey I just saw this thread and I immediately went out to my 03 sedan and measured the holes where my emblem used to be. Some **** stole my "H" back in November. Anyway, I measured with a measuring tape and the distance between the center of the two holes is exactly 2 cm.
Old Jan 31, 2004
slamtank's Avatar
i just measured the distance between two pins on the back of emblem
and it was 2.15cm.
now the emblem wont fit without modifying it..
also coupe's trunk is kinda little round
but the emblem is flat..
im not installing this..
i will find another way to use it unless hondawerx dont refund it..
Old Jan 31, 2004
egot2da4th's Avatar
and it was 2.15cm.
just resell it on ebay....
Old Jan 31, 2004
civicvtec1ps's Avatar
Search and Learn
Dude, honestly come on now.
Just put it on. Adhesive on the back works PERFECT.
You won't need to use pins on the back.
Old Jan 31, 2004
dalaw's Avatar
Bone Stock!
and it was 2.15cm.
Hey I just went out to my car once again to measure the wholes with a ruler and the distance between the center of the two holes is more like 1.8 cm, not 2 cm as I previously measured because that measuring tape I used earlier was kinda f**ked up.
Old Jan 31, 2004
dalaw's Avatar
Bone Stock!
Originally posted by MREEZYSMRS
They stole your H emblem??????
WTF?
I don't know if that's funny or pathetic ,or funny because it's so pathetic!
Yup, that's pathetic. Here is the thread about this.
http://www.7thgencivic.com/forums/sh...=emblem+stolen
Old Feb 1, 2004
slamtank's Avatar
think you need to read whole post or something..
even tho i dont need to use pins on the back..that means i have to cut those pins out..
its not the way that its supposed to be. (i kno sometimes i have to modify something to install)
in addition, i said the emblem is flat while my trunk is kinda round..
should i just put it on?
Old Feb 1, 2004
Search and Learn
No, I do not need to read whole thread again. Because I read it already.
What's the worst scenerio would be?
You just lose pins on the back of the emblem and Adhesive.
Trunk might be SLIGHTLY round. I am sure emblem will fit just fine.
It's your choice.
Should you just try to put it on? YES.
Old Feb 2, 2004
slamtank's Avatar
It's your choice.
o you meant that..
well you have more experience than me..haha
of course im gonna try it..
Old Feb 3, 2004
silverem2's Avatar
yup, thats what im doing, mine has a SLIGHT curve and i mean slight, almost nothing, so im gunna cut or shave the pins off and sticky it on...
Old Feb 3, 2004
slamtank's Avatar
ati9700pro, could you pm me or something after you ve done that?
Old Feb 4, 2004
silverem2's Avatar
ya, sure, i wont be doing it till the summer tho, cause it wont stick worth **** in the winter
but ya.....if you can wait that long
jessicakaybby
Apr 20, 2015 12:11 PM
cable
Dec 13, 2001 05:13 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
trevaaaa
Oct 10, 2001 01:23 PM
