FS: Turbo Kit UPDATE PICS 1st post
Old Jan 27, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
UPDATE BELOW ORIGINAL POST
This is a long post, so read through it to the bottom w/ footnotes[*].
This is more or less to look at offers. The probability of selling is pretty high due to circumstances. I moved a few months ago and don't really use the car much, so I'm deciding to sell. I'd rather sell everything as a whole kit, but I'm pretty sure most can't afford that.
Feel free to post REASONABLE offers and ask questions. Individual pricing will be posted soon. (NOTE: This includes everything you will need including hardware, vaccuum lines, etc. ) If you don't feel like posting here, catch me on AIM: Boosted2k2.
EVERYTHING WAS BOUGHT BRAND NEW AND IS IN EXCEPTIONAL CONDITION.
- Turbonetics T3/T04B upgraded and polished. Had it custom built to match
engine output (which it does perfectly)
- Stafford Fabrication Custom IC piping (same as Catalyst's new setup... allows for opposite end IC tanks) Not powdercoated, but I can powdercoat any color free of charge. Includes couplings and filter. Pipes were beaded at a shop here so they don't leak or move around, and probably never will.
- Stafford Fabrication Manifold and EX Downpipe (Flanged for any T3, and for a 35mm Wastegate. Wastegate is recirculated into the downpipe. Downpipe has no O2 bungs due to my setup.
- Spearco FMIC: 26x6x3" Core with mounting bracket. Inlet and outlet tanks on opposite sides. Fits behind the stock black grill with out too much shaving. Looks clean.
- TiAL 35mm wastegate. Has a .3Bar spring. Meaning that without a boost controller, this setup is made to spool 5psi out of the box, but with a boost controller (5psi - infinity).
- GReddy Type S Blow Off Valve
- GReddy PRofec E01: Multi Display Electronic Boost Controller with handheld controller, pretty accurate and user friendly. Data logs any three channels (even if you make them up) for three hours on a 8MB SD card. E-manage programmer (rids of the use of carrying around a laptop in
the car)
- GReddy E-manage w/ all harnesses: Controls Ignition Timing, Injector pulse, Auxilliary injector pulse, MAP signal, etc etc.
- Oil Feed and Return lines: All braided stainless steel lines with all necessary fittings.
- Weapon R Chrome Oil Catch Can w/ lines: Not so much in terms of catching oil as it is used to improve engine breathing. It gives the crancase proper ventilation that a lot of others haven't done (hence some have oil in the engine bay) I don't
- Full Return Fuel System: Truly Plug and Play [***]
- Modified Stock Fuel Rail
-Stainless Steel Return Lines
-Aeromotive Fuel Pressure Regulator and Fuel Pressure gauge
-Brackets and all fittings
-Complete In-tank assembly with upgraded fuel lines and a Walbro 255lph fuel pump.
- GReddy Full Auto Timer (Turbo Timer)
- Gauges +: [****]
- Autometer Ultra Lite Oil Pressure Gauge
- Autometer Ultra Lite Boost Gauge (0-35psi)
- Autometer Ultra Lite A/F Gauge
- Autometer Triple Guage Pillar Pod
- KMS Intake Manifold
- Random Technology Hi Flow Catalytic Converter (50 State Legal) w/ primary and secondary O2 bungs.
- HPRacing Jspec Cat-back Exhaust.
- EX Sway Bar (if fitting all of this on anything other than an EX
- ALL HARDWARE INCLUDED
NOTES:
-Return Fuel System***: Can lower price if trading OEM parts (Stock Fuel Rail and In-Tank Unit w/ OEM pump)
-Gauges****: If you have a coupe with a grey A pillar, I will include mine (already drilled to fit wires) for trade of your stock pillar.
UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
Below are prices for the whole kit. If anything is vague (and I bet some is), please get me on IM (Boosted2k2) and talk to me.The price of $4600 is for everything. Lower with trade for my required OEM parts. I'm dealing with people that want to buy the whole kit rather than parts first. If nothing reasonable comes out of it, then I'll make new prices and part out.
If you think my price is too high, I'm supplying the list of prices for retail and asking for the KIT. Parting out prices would be a little higher. For a rarely driven car, I feel I'm being more than fair on this deal for a one of a kind kit.
Suppose you were going to get an SF kit: $3000
Add all of this on:
External Wastegate
Polished and Upgraded Turbo
Fully converted Return Fuel System (Fuel Rail, Stainless Steel lines and pump)
Fuel/Ignition control
Electronic Boost Controller w/ logging and programming capability
Better fit/Look FMIC
Better Sounding/looking BOV that goes Psshhh and not whoosh
Engine breathing system
Intake manifold
Autometer Oil Pressure, Boost, A/F Gauges, and pillar pod
Stainless steel Oil return line
Every peice of hardware you need
I'm positive you are going to reach around $6000. The fuel and boost controlling system alone is $1500 brand new.
Take a look and come speak to me.
SS Oil Return:
GReddy FATT:
Kit:
Autometer Gauges & Pillar:
GReddy Emanage:
GReddy Profec E01 (Boost Controller/Emanage Programmer/Datalog):
Polished Compressor Housing (Turbonetics T3/T04B):
Return Line (Tank):
Return Line & Rail:
Old Jan 27, 2004
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
Pm'd you
Old Jan 27, 2004
robbclark1's Avatar
Retired suspension supermod.
Alex's Kit OWNZZZZZZZ. A lot of stuff for a great kit. He has hand picked this stuff out so you know you are getting great parts! Free bump and plug for Alex!!
Old Jan 27, 2004
SimplySLB's Avatar
Ms. Moderator
SimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to all
I'm gonna post in here too!
I drove the car, it's just awesome. I don't know much about turbos and the like, but everything I do know I learned from Alex and his stuff....so what he's got is definitely some GREAT stuff. Wish I had the money, I'd buy it sooner then you can think about it!
**A little added bonus. Alex is a very trustworthy guy. If you buy his stuff, you know you'll get exaclty what he tells you, you are gonna get. And he knows SO much. So, if you needed help...he's your man.**
Old Jan 27, 2004
Boosted2k2's Avatar
Re: FS: Turbo Kit +++ UPDATED!
Old Jan 27, 2004
SimplySLB's Avatar
Ms. Moderator
SOMEONE BUY THE WHOLE KIT....I NEED A DOGGIE!
Old Jan 27, 2004
Blueboi105's Avatar
Blueboi105 is an unknown quantity at this point
I'll trade you a dog for the kit.. lol jp
Old Jan 27, 2004
gotti's Avatar
I'll trade 2...no make it 3 and a year of free vet checkups.
Old Jan 27, 2004
AlpineCivic's Avatar
will anything need to be modified for an EX? and how much less would it be if I bought the whole kit and traded the parts you need.
Old Jan 27, 2004
Boosted2k2's Avatar
Nothing needs to be modified if you are trading the parts. If you weren't trading any parts, you'd have to modify your A - pillar to fit the wires through for the gauges, and you'd have to weld the stainless steel oil return line to the pan.
I have an LX, but everything fits EX/LX/DX. The only thing is that I need to quickly check the EX engine bay to make sure the piping fits in one spot. I will be doing that in a day or so. Although I am pretty sure it all works out. I'll keep everyone posted on that.
Old Jan 28, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
hey guys BUY THIS~ 99.9% of the miles on the kit are HWY miles from NJ to CT.
Turbo was never abused, in its short span of use.
This is a great deal for ne one, Ive been in the car and its very quick.
Dibs on the e-manage and the return line, if u DO part it out.
btw.. whats mom got to say about losin the boosted civ
Old Jan 28, 2004
Boosted2k2's Avatar
You're surprisingly the first person to ask about the E-manage. I thought tons of people would want one.
She doesn't know yet. She'll probably make fun of me and call me slow or something haha.
Old Jan 28, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
damn that was a lot of cash you put out for your turbo.
Would have been better for a swap!
Old Jan 28, 2004
Boosted2k2's Avatar
What do you mean by a lot of cash? I got good prices for everything. I just added on options for a better kit. If I wanted a swap, I would have swapped. If I did swap, I'd be selling that too. Not to mention that the prices here for retail and asked cover the cost of OEM parts I have to buy if someone doesn't trade them. I am including them making this a pure bolt on without modification.
Old Jan 29, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Can you post some pictures!
Old Jan 29, 2004
Boosted2k2's Avatar
Yeah, when I get a chance to take them.
Old Jan 29, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
Intercooler
Return line on fuel rail
Old Jan 29, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
oh and alex... i know ur not taking a 350 dollar loss on the fuel rail, just cause u need a oem one.
if all u need is the rail to resort back to stock, then ill kick ur *** if u sell it for 350 instead of more.
my OEM fuel rail,wtih injectors- is sitting on my desk. come and get it , its urs.
Old Jan 29, 2004
Boosted2k2's Avatar
Thanks a lot Vin! Also, those pics are bad. I need to take some during the day.
Old Jan 30, 2004
Boosted2k2's Avatar
Maybe I should clear up the fuel system info.
The $350 is not a price that is just in trade for the fuel rail.
You get:
My fuel rail, all return lines, fuel pressure regulator, 255lph fuel pump, my WHOLE INTANK UNIT, all the fittings etc etc.
in return you give me $350 and:
Your fuel rail and your whole intank unit.
Without a trade, it will cost me around $350 to replace OEM parts. I'm not exagerrating at all on this price, so don't think I'm trying to screw anyone over. If you want to keep your OEM parts, you still get mine and the rest of the fuel system at a price of $700, which allows me to replace my OEM parts without losing money.
For the EX owners, I'm checking the EX tonight for fitment. I will post on it later. And provide pics of the kit later.
If the streets aren't icy tonight, maybe I'll post a video tomorrow. Or at least some soundclips.
Old Jan 31, 2004
Boosted2k2's Avatar
Pictures are updated and in the first post. I didn't take pics of everything because my camera batteries were dying, but all of the main important components are there.
I apologize if I led anybody on by this, but the intercooler piping does not fit an EX, I checked this morning. The only interfrence is the ABS modulator. I'm assuming that all EX have ABS. The only way to get the piping to fit would be to relocate (not hard exactly), but then someone would have to rebend all new lines and I'm sure that is expensive and not worth it. Other than that, everything else would fit.
I'm going to start parting out in a few days Anybody that sent me PM's on parts, I still have your names and everything. You can still PM me and IM me again to make sure I don't forget if you want. I'm getting old.
Old Jan 31, 2004
Balut Eating Champ
Damn swwweeettt!!!! why is way too much bro? FS selling their whole set for 3500 right? awesome pictures!
Old Jan 31, 2004
Boosted2k2's Avatar
SF's kit doesn't include a boost controller, engine management, a return fuel system, intake manifold, exhaust system, ss oil return line, turbo timer, gauges and pillar, and more... etc etc etc. This kit doesn't even share the same intercooler piping, turbo, blow off valve, intercooler, wastegate or routing. This kit resembles other SF kits only by the manifold and downpipe. If anybody seriously thinks I am selling this for too much (which nobody has said yet), then you've got to be crazy.
Old Feb 2, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
how far are you from union nj. i already contacted you about the whole kit im just waiting on my boy to check it out and make sure he wants to do it.
Old Feb 2, 2004
Boosted2k2's Avatar
I think about 10 minutes from Union.
Old Feb 2, 2004
cool thats where my dad lives so its not to far .i forgot to ask y r you takin off the turbo kit???? and if we cant set up a meeting so i can see everything in person. id feel safer no offence. prob next weekend. e-mail me @
Dan@team-upgrade.com
Old Feb 2, 2004
Balut Eating Champ
how much gain did you get with the whole set up? your kit sounded pretty intense! only if I have enough cash!
Old Feb 2, 2004
Boosted2k2's Avatar
I'm taking the kit off because I don't even drive the car that much. I just moved here. So what it comes down to for me is wondering whether taking the couple ride I do with a turbo'd car is worth more than the money, it's not for me at this particular moment. When I graduate, I plan on doing this to another car other than a daily driver. That's my reasoning. There is nothing wrong with the car or the kit. Runs fine.
Contact me on a meeting or something. I don't want to really hold out too long because I have a bunch of people willing to buy parts if it doesn't go through. But I have no problem with your inspecting it. I'm totally confident in the kit.
Old Feb 3, 2004
pm-ed u
Old Feb 4, 2004
im bringing my friend who knows alot more about this than i do. if you were buying a 4500 doller computer youd want someone who knows alot about them to help u right?
