K-series swap ECU question.
Old Jan 26, 2004
Jodster's Avatar
Post Whore General
Ok, I know that when you swap in the K20A2 you can run the motor on the D17 ECU untill you get to Honda to get the K20A2 ECU Flashed, but what about the K20A3 or K24 motor? What I mean is, the reason you flash the K20A2 is because of the higher redline and the different Vtec engagements on the true Vtec with the DOHC. But the K20A3 and K24 only have Vtec on the intake cam just like the D17, but of course is DOHC. Anyone know what the Vtec engagements are on the K20A3 and K24? Are they the same as the D17? If so, I don't see why you could not use the D17 ECU with the K20A3 or K24 instead of changing to the K20A3 ECU. All three motors has a 6800 RPM redline. Thoughts? I was just wondering.
Old Jan 26, 2004
Hawk's Avatar
You boost, I-VTEC
Re: K-series swap ECU question.
you have to remember that the fuel maps are way different on the k-series motors, and that the D17 ECU is made to run a SOHC motor, not dual. When i was running my car on the Civic ECU it ran really rich, i couldn't even drive the damn thing, i towed it to Acura. Any k series swap your gonna have to swap ECU's too.
Old Jan 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
just out of curiosity, why use a d17 ECU on a bigger and better motor
Old Jan 26, 2004
Jodster's Avatar
Post Whore General
I was just wondering. I thought that the D17 ran the motor fine, just had different Vtec engagement. I guess I was wrong. oh well.
Old Jan 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
no sweat, life=learning as u go
Old Jan 26, 2004
Jodster's Avatar
Post Whore General
Well I figured if it work, why would I need to buy the other ECU. Just thinking money wise. But it doesn't work. Oh well. LOL
Old Jan 26, 2004
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
the RSX ECU should of come with your motor. If it didnt, then that was a bad deal. Like Hawk said, teh fuel maps are way different, and the car will run really rich. I had all kinds of back fire when i drove on my civic ECU. It was kind of funny for a while, then got really annoying.
Also, a nice little trick for the ECU placement is, open up the RSX ECU and just unscrew the guts of it. Its one panel, dont worry. Then do the same with your civic ECU, and place the guts from the RSX ECU into the civic ECU case. this way it bolts up nicely to your car.
Thats what i did anyway.
Old Jan 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
genious i tell you genious
Old Jan 26, 2004
Jodster's Avatar
Post Whore General
Cool. Thanks man.
Old Jan 26, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
SO do you take it to honda or acura to flash the keys so the immobilizer works?
Old Jan 26, 2004
Hey Jodster...check your PM's, ive been tryin to contact you.
Thanks
Old Jan 26, 2004
Taking it to either Acura, or Honda will work. If you take it to Honda, they will need to contact Acura to get the breaker code for the ECU. Which can only be obtaned with the VIN off of the motor...so make sure you dont have a stolen motor where the VIN is scratched off.
Old Jan 26, 2004
kjgracing's Avatar
Thanks NBJT!
Old Jan 26, 2004
No problem...anymore questions, please feel free to PM me at any time, and i will get back to you as soon as possible.
That goes for everyone.
Old Jan 26, 2004
Hawk's Avatar
You boost, I-VTEC
Yea isn't it a beutiful thing that the k20's ecu guts fit in the Civics ECU casing?
Old Jan 26, 2004
Makes things a lot easier thats for sure. It was still a little bitch to get that ECU out though. I didnt have a helms, there might of been an easier way, but i had jsut a bitch of a time tryin to pull it out.
Old Jan 26, 2004
Hawk's Avatar
You boost, I-VTEC
if you can beleave it, you are actually supposed to cut the plastic peice that covers the metal brace behind the glove box to get it out. It's really funny if you look in the manual how easy they make it seem and how hard it actually is to do.
Old Jan 26, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
where is the vin # at on the motor? I thought that is was only on the body of the car?
Old Jan 26, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
so if u have a reciept and a good VIN you can get it flashed for free? or what?
Old Jan 26, 2004
Hawk's Avatar
You boost, I-VTEC
not free unless you know someone. They only charged me for labor which was 2 hours so 180 bucks. Not bad if you ask me.
Old Jan 26, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
thats not too bad at all... i expected alot more.
Old Jan 27, 2004
They did an after hours thing for me, and i got it done for free. Weird huh? I had lkie $200 in my pocket ready to go too.
Atl01: the VIN i believe is located on the back of the motor. Once you get a motor just look around for it, you will see it.
Old Jan 27, 2004
Hawk's Avatar
You boost, I-VTEC
its actually on the bottom by the axle i had to look for mine to get my title. Its a green plate, kinda hard to miss
Old Jan 27, 2004
Jodster's Avatar
Post Whore General
Ok what if you get the K24 motor, K20A3 tranny and ECU. How will Honda Flash your ECU then? It wouldn't be the same ECU from the motor, but can they flash it?
Old Jan 27, 2004
briang's Avatar
briang is an unknown quantity at this point
Guys, you need the VIN from the car you got the ECU from. It is needed to get the daily security code for the ECU from Honda. If the dealership doesn't have this, they cannot flash the ECU.
brian g
Old Jan 27, 2004
Jodster's Avatar
Post Whore General
^^^^Thanks.
Old Jan 28, 2004
2Fast2Furious's Avatar
2Fast2Furious is an unknown quantity at this point
One word for you HONDATA
Old Jan 28, 2004
Jodster's Avatar
Post Whore General
Re: Re: K-series swap ECU question.
Hondata for what? The D17 ECU? They don't make one for the D17 ECU. And If your talking about adding Hondata to the K20A3 ECU, that will not be the same as the K20A2 ECU meaning the true Vtec. Plus Hondata doesn't make a FI application yet and it would be pointless for me to get it. Cause I'm swapping and boosting.
Old Jan 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
Re: Re: Re: K-series swap ECU question.
and thats that
Old Jan 28, 2004
Jodster's Avatar
Post Whore General
^^^^^^^^LOL true.
