clutch make crackling sounds...
Old Jan 20, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
my clutch is making sum crackling sounds when i press it half way and hit the gas... what is that?/
Old Jan 21, 2004
reflekt's Avatar
reflekt is an unknown quantity at this point
maybe the bearing in the clutch. thats about a $500 fix right there. :\
Old Jan 21, 2004
armieo's Avatar
< My future wife.
I see people buying ACT flywheels and pressure plates or wutever and all that hoohah. Being a n00b and all, I wouldn't know what that does. Say I've peeled out like only 4 times in the year I've had my car and the clutch pops out once in a while and the car shudders in 1st and 2nd when putting it into gear sometimes. Would replacing all these things be helpful?
Has anyone actually DIY-ed it?
Old Jan 21, 2004
solar's Avatar
solar is an unknown quantity at this point
Maybe the clutch pedal is just squeeking.
Old Jan 21, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Mine did that ... just remove the panel below your steering wheel and
spray silicone or use grease on the entire clutch pedal arm (where the pedal goes up into the engine bay)... coat all the metal and moving parts you can see (or feel) and it should be fine.
Old Jan 23, 2004
reflekt's Avatar
the way he had described it tho, it sounds like a clutch bearing.
if he said it makes the sound by simply pushing in the clutch, without gas, and it made a muddled squeek type of noise, then thats just a quick fix with some silicone grease.
but he said he makes the noise when pushing the clutch in and pressing the gas. i had that problem on my previous car, and it was the clutch bearing.
Old Apr 5, 2004
Elite's Avatar
Elite is an unknown quantity at this point
mine makes a noise I know its the clutch pedal cuz I got mine from a junkyard and it was all dirty I should have greased and cleaned it before.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
S.Klinck
Jun 11, 2015 10:27 PM
jbander
Jun 4, 2015 05:56 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
bsmiley
Apr 27, 2015 01:27 PM
