Power cable Vs. Speaker wires
question, in order to get my speaker wire into the passenger door, i need to cross over the power cable running along the passsenger side panels.
Will this cause sufficient noise in the audio signal?
Also, according to the DYI on the amp wiring, it says to run the power cable next to another cable that runs along the passenger side.
Isn't this cable the antenna cable? Won't that mess up the radio signal?
Not that i really listen to the radio anyway, but i still would like to know.
Will this cause sufficient noise in the audio signal?Also, according to the DYI on the amp wiring, it says to run the power cable next to another cable that runs along the passenger side.
i have the power running on passenger side. no radio problems.
speaker wire and power wire are buddies. they don't interfere with each other. RCA's are what you must worry about.
mohawkboom
67
Aug 25, 2015 12:28 AM
Wild Cranker
May 19, 2015 06:10 PM
Shakzhussain
May 17, 2015 12:03 PM
Dmitri
123
Oct 13, 2005 08:01 PM
