DIY Indiglo gauges (94 accord)
Old Jan 12, 2004
clownprince's Avatar
Ricerus Maximus
A friend of mine needs help with his gauges and I can't seem to find any info on his car. Luckily all of you guys here have done numerous DIY's that are easily read and followed. However since this is a civic website there's no accord tech stuff. Has anyone on here done any work on a 94 accord gauge cluster that can tell me which wire is equivilent to the red/black wire i tapped into on my car? I just need the switched power source to finish prepping for the install. Thanks
Clown
Old Jan 12, 2004
tfnaaf's Avatar
BLDNPSI Mod
Hope this helps
Current Vehicle:
1994 Honda Accord
Item Wire Color Polarity Wire Location
12V white + ignition harness
STARTER black/white + ignition harness
IGNITION black/yellow + ignition harness
ACCESSORY yellow + ignition harness
SECOND ACCESSORY none
TACHOMETER blue at distributor
POWER LOCK black/white - gray conn. above fuse
POWER UNLOCK orange - box in blue tape
PARKING LIGHTS + red/black *1 blue plug fuse box
PARKING LIGHTS - none
DOOR TRIGGER blk/wht - gray plug right of column
HEADLIGHTS blue - blue plug left of column
WIPERS blue - brown plug left of column
LF WINDOW UP/DN red/blu - red/yel A in drivers door
RF WINDOW UP/DN blu/yel - blu A driver door harness
LR WINDOW UP/DN grn/blu - grn A driver door harness
RR WINDOW UP/DN yel/blu - yel A driver door harness
TRUNK/HATCH PIN orange - gray plug right of column
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM none
FACTORY ALARM DISARM none
HORN TRIGGER blu/red or grn/blu - steering column
BRAKE WIRE green/white + brake switch
LOCK MOTOR none
UNLOCK MOTOR none
DISARM DEFEAT none
DISARM NO UNLOCK none
DOME SUPERVISION use door trigger
SPEED SENSE none
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER none non none
RF SPEAKER none non none
LR SPEAKER none non none
RR SPEAKER none non none
RADIO 12V none non none
RADIO GROUND none non none
RADIO SWITCH none non none
RADIO ILLUMINATE none non none
POWER ANTENNA none non none
Notes: *1 Also a male blade terminal is available in the fusebox DKP.
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
srtlat
Sep 17, 2015 11:02 PM
