push button start!!
Old Jan 9, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
push button start!!
ok.. so im stuck right now... im trying to figure out which wires im supposed to tap into
i dont want to use relays, so im trying to figure out which wire im supposed to have connecting in order to start the car
i would still like to use the key
ill start checking other wires...
pm me please about it
heres what i tried so far
starter wire has not changed.. black/white
my switch has 4 contacts, 1 for the direct power, which i chose to connect to the battery(-4 is what they labelled it)
1 to ignition wire(-3) i tapped into the black/white wire
1 to ground (x2) i just ran it straight into my ground
1 to power when the ignition is on (x1) black/red wire..
this is the right wiring as far as i know.. but nothing happens...
i press the clutch, and the button, but nothing
Old Jan 10, 2004
WannaBFast's Avatar
ok.. well it lights up when teh key is in teh on position... but when i press the clutch and press the button, i get nothing... im gonna close up shop for tonight and figure it out in the morning...
Old Jan 10, 2004
WannaBFast's Avatar
figured it out
Old Jan 10, 2004
abmerop18's Avatar
Jam out with your clam out.
well, tell the rest of us how to do it. a DIY would be nice too
Old Jan 10, 2004
7thGenerasianCivic's Avatar
isn't there a DIY on this?
http://www.7thgencivic.com/forums/sh...threadid=28462
Old Jan 10, 2004
civicvtec1ps's Avatar
Search and Learn
Ive read Sooo many DIY's all over the place last night. Most people used relay, You dont need it at all with OEM honda starter button. I am not sure about other brands, such as euro type r,ignited. Those are similar starter buttons are wirings are little different.
This is all i did. 3 wires coming out from s200 starter button. one fo ground, power and starter wire. I got power and ground from cig plug wire. Then last wire is just directly tapped into starter wire(black and white) from ignition plug(brown). Works perfectly. I didnt want to use relay, because they arent really any space to work on, I have all damn wires from volt gauge, headunit. Wiring was way simple than i thought it would be. So you would not need relay with oem honda start button.
Heres pictures.
Starter wire(black and white)
Ground and Power
Results
I was going to relocate hazzard button but whole wireharness wanst long enough to do that. I lost 12v cig plug but i can always hardwire radar detector. No big deal. Only problem was damn cold weather.
Old Jan 11, 2004
Unleaded's Avatar
Unleaded is an unknown quantity at this point
i might do this now that i know to use the S2000 starter button. question, if i buy the starter button from the dealer, does it come with the wirings or do i need to make my own?
Old Jan 11, 2004
WannaBFast's Avatar
i think it only comes with the button and harness not the wires
the kit i got doesnt need a relay either, hooks up just about the same way just also has to get power from a direct, constant source like a battery or white wire under the steering column
basically its hotwiring your car, but it still needs the key because of the immobilizer
Old Jan 11, 2004
Unleaded's Avatar
gotcha. from the picture below, looks like a little hard-wiring must be done to the back of the button assembly. any diy for that part?
Old Jan 11, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
ive already read everything the diy and everything i can find on it but my question is this. how do you wire up the s2000 starter. i dont want to have all the switches like in the diy. i just want to have the button work when you turn the key to the on position. do you have to have a relay for that or do you just wire it up. and does the button come w/ a way to wire it cause by the looks of the pic that unleaded posted it looks like you have to find some way to wire to the prongs in the back or does it have a harness that plugs into it.
Old Jan 11, 2004
Search and Learn
Check out this auction. Everything is pre wired.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2453701079
realitycheck
Pmed back.
Just made video clip.
http://www.imagestation.com/video/pl...?id=4194004517
Old Jan 11, 2004
ok first i couldnt get the video to work. and second the ebay one says that if you do not have a relay the switch will eventually fail is this true and if it is how do you wire up the relay w/ the switch. and if i buy one from the honda dealer i would get switch and buy the harness w/ it of course. so what kind of relay would i need to get.
Old Jan 11, 2004
Search and Learn
Diagram
http://www.miata.net/garage/pushstart/
Genuine Honda S2000 start button, you do not need a relay.I am confused why the people that you picked up the kit from said it was required. My kit came with all wires and relay. I cut relay out and didnt use it.
Old Jan 11, 2004
ok cool so i dont have to use the relay then just go buy the switch and the harness and wire it like you said and im ready to go right
thanks man
Old Jan 11, 2004
Search and Learn
thanks man
No problem, Connect 3 wires and you are good to roll,
I am not electrical garu, no idea why relay would be needed to installl starter button.
If anybody knows about this,let me know.
Old Jan 11, 2004
vira3's Avatar
vira3 is an unknown quantity at this point
end of day thanks to civicvtec1ps
Old Jan 12, 2004
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
civicvtec1ps did you get your kit off of ebay??
Old Jan 12, 2004
Search and Learn
No, I didnt.
I bought it from clubrsx member. It is same kit though.
Old Jan 12, 2004
ok i have one more question for this maybe another but hopefully not. i read part of the mazda forum and it said use a 30 amp relay but our diy said use 50 amp relay i need to know which one to use and what type should it be like spdt or what.
thanks
Old Jan 12, 2004
Search and Learn
The voltage is really the same. the 12v referes to auto systems which are really at 14.4 volts as determined by the altenator regulator. the amps is the max that the points will handle without arcing, overheating & melting together. You will be perfectly fine with 30amp relay.
http://www.partsexpress.com/webpage....ectGroup_ID=31
Old Jan 12, 2004
okay last question i promise i cant find a single pole double throw relay at radio shack my local one or the net. so can i use the single pole single throw or does it have to be the spdt. thanks
Old Jan 12, 2004
Search and Learn
Yeah you want to make sure it's an SPDT and not SPST.
Did you check link i posted right above? You can order SPDT from partsexpress. If 87a does not have any use since nothing is attached to it therefore a SPST can be used.
http://www.the12volt.com/relays/relays.asp
Old Jan 13, 2004
WannaBFast's Avatar
if i could do it again.. i woulda gotten the s2000 start button.. cause with the ignited, you can crank the engine without the key.. so ill be back at rewiring the whole setup so that it works like i want it to work
Old Jan 13, 2004
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
So now there's an entire kit for the S2000 starter button? When I did mine last year it was just instructions from various sites, a button from h and a, and a single pole double throw relay (radio shack). Also, an old floppy drive (cpu) pin connector works great for connecting to the back of the button and then you can just splice the wires. I wasn't able to get my button to work without the spdt relay.
Good luck. I think my diy was lost (team web site).
Old Jan 13, 2004
WannaBFast's Avatar
well you really dont need a relay...
you just need to hook up the acc or power when the car is on.. the ground.. and the starter wire.. then your golden
civicvtec1ps did it very easily so there isnt any reason why you cant
Old Feb 26, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Civicvtec1ps' setup looks awesome in that Ep3.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Laurenhunter7
May 10, 2015 01:09 PM
ZSKCivic01
Jan 5, 2002 12:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
nickfn
Nov 30, 2001 11:13 AM
