box specs, can someone check me
Im going to make a sealed enclosure for my sub so tell me if this makes sense
im going to make the box 14"w X 14"h X 12"d (inside size) which should give me a volume of 1.36 cu.ft.
The speaker displacement is .066 cu.ft, and the braces i use will take up .060 cu.ft which will leave me with a volume about 1.228 cu.ft
The recommended sealed box vol is 1.25 cu.ft.
Will this be ok, and does this size sound right?
The reason why im confused is in the instruction book for the sub it shows a box 14x19.75x12
that gives a volume of 1.92 cu.ft. (1.85 cu.ft if you take into consideration the sub displacement.) So that leaves .6 cu.ft. Why would it show a box with that volume when they recommend 1.25, or am i missing something.
Here are two pages for my sub
