Tips for removing stripped lug nut?
Old Dec 31, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
My open end lug is stripped... BADLY... if i got a power drill with a stripped screw bit attached, would that h ave enough power to torque it out? I thought of painting the surfaces of my wheel key, and inside of the lug, then stuff it w/epoxy, put the key in, let it dry, and see if that can get some traction on thet stripped lug... I REALLY hope the key doesnt dry onto the lug or the lug doesnt dry onto the STUD, that is why i will prep w/ paint... good idea? i can take it to the shop to use an impact gun, but they said it is guaranteed they will damage my rim
Old Dec 31, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
theres a tool for it...the thing is tapered and goes on with a hammer gets stuck on and turns it off that way
Old Dec 31, 2003
VTECnique's Avatar
VTECnique is an unknown quantity at this point
i got one that looks like a normal socket but the inside has a swirl pattern to grip the nut/bolt/lug. you can also use an ordinary socket thats slightly oversized socket and bang it on, then use a breaker bar t loosen it.
Old Jan 1, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
wut u can do is get another lug.. screw it real close to the stripped lug.. and weld them together. then thurn the good lug and it will come out.
Old Jan 1, 2004
bth Go Army's Avatar
bth Go Army is an unknown quantity at this point
yeah wel;d something to it i did same thing
Old Jan 2, 2004
jjj784's Avatar
jjj784 is an unknown quantity at this point
jb weld
Old Jan 3, 2004
pheaton's Avatar
A descendant of 2k1civic.com
^^ I agree. Welding something to it works most of the time.
Old Jan 3, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I'm assuming if its open end, its aluminum too...
Makes things a little uglier.
Since its open, you could try to screw an M12x1.5 bolt into the end, if you can catch a few threads then try some super-epoxy and wait until it cures (give it 24-36 hrs), then see if you can back it out using the bolt head. Another thing people do with those krapokugens which strip all the time is hammer a 12 sided socket onto the nut and slowly back it out.
I don't know if I'd try welding. Welding aluminum is tricky, and you'll probably mess the wheel finish up with the heat.
There are those stripped bolt removers, I don't know if it'll work.
Last resort, drill the stud out. It'll get the nut off, but then you'll have to replace the stud too.
If you try the screw remover (the cone thing with the left handed threads), get a very fat one so that just the tip of it goes in the nut. there isn't much room before you hit the stud. I'd do it by hand, power tends to just burn the teeth off those things. Get a T-handle with a long bar, have someone hold the bit in place then turn the breaker... if it comes loose, you're in business. No guarantees though.
Old Jan 3, 2004
IrockCivics's Avatar
I caught a flat 2day and I took 3nut's out and when I went to take the 4th one out it turn and turn and turn but the nut did'nt loosend up or nothing so yeah I got stuck with a flat and still am. What should I do?
Old Jan 3, 2004
2k1civic.com O. G.
goto a tire shop if u cannot get it out yourself, im sure they deal with these situations all the time.
Old Jan 3, 2004
Jonauto's Avatar
Jonauto is an unknown quantity at this point
i u dont care about f'in the lug up u can just take a dremmel and cut a slice in it and then turn it like a big flat head screw....
JohnnyBxo
Nov 12, 2015 03:04 PM
Jul 12, 2015 11:54 AM
General 7th Gen
Jul 9, 2015 10:17 PM
silentz
Jul 9, 2015 08:16 PM
Ccoop87
Jul 9, 2015 03:26 PM
