components
components
I was thinking of adding components to my car, if I do could I do the following.
Front output to amp in located in trunk, from trunk to wiring harness in dash to tap into factory wiring for fronts. Or do i have to run new wires into the door, will it be better if i run new wires into the door, and is it hard to get through the door.
Also I have polk db650 up front and db690 in the back, should I get the polk db components or would you recommend something else
the factory wiring is kinda thin to support components. just run new wires and leave the stock ones there. def. worth the trouble.
you can buy any components you want. in the front you won't hear the rear speakers running off the deck really.
it's not that tough to run wires through the door
ZoSoIV
Sep 17, 2015 07:17 PM
violentpanda
Sep 7, 2015 11:49 AM
