Clutch noise
Old Dec 16, 2003
ninerfan17's Avatar
ninerfan17 is an unknown quantity at this point
Clutch noise
Every time i activate the clutch there is a popping sound? It always happens right when i first put preasure on it with my foot. Does anyone know what is causing the sound? Could it be a loose bushing or something like that? Please help!!
Old Dec 16, 2003
Bigmac's Avatar
Bigmac is an unknown quantity at this point
I have the same kind of noise...(starting to get on the brake pedal too)
wondering what it could be...
maybe a lack of oil in the pedal???
Old Dec 16, 2003
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
its your TRANS>........
Old Dec 16, 2003
Dr5D's Avatar
Id be scared. Take it to honda, assuming you havent done anything to the tranny area, and the warrenty is not up.
Old Dec 16, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
I always have that sound and I thought it was normal.
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
is it just the pedal squeaking, bc i have that its a lack of oil, bc i oiled it, it stopped and then came back..............just turn the music up
Old Dec 17, 2003
Bigmac's Avatar
lol "turn the music up" thats what i do...
but i still feel it on the pedal...(when you press on it, its not smooth)
i'll add some oil to see what hapens...
Old Dec 17, 2003
SPORT2087's Avatar
SPORT2087 is an unknown quantity at this point
i had the same problem and i took it to handa to get it fixed they said it was the main bearing in the trans. they keep my car for three weeks so i hope that you have another car to drive
Old Dec 17, 2003
Bigmac's Avatar
holy ****!! 3 weeks...that must be some serious crap...
but did you pay for it? or it was under warranty???
Old Dec 17, 2003
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
I just managed to solve my squeeking clutch sound today. This may work for you guys having the pop noises. Anyway there are 2 ways to solving it..
1. Cut a slit in the rubber boot that covers the clutch slave cylinder. Spray WD40 or some lubricating oil into that area. Viola! Less than 5 minute job. Sound goes away. This was what the lazy dealership did to my car without me knowing until today when I decided to fix the problem myself.
2. This method is the proper way to administer this problem. First, remove the clutch slave cylinder by removing the 2 bolts that hold it to the engine block. DO NOT remove or lossen the nut that holds the DOT fluid line in place to the cylinder. Pull back on the squarish rubber boot so that you can move the cylinder aside. Remove the squarish boot. Now you can have a rough idea of how this thing works. Anyway, grease the cylinder end that comes in contact with the lever which can be clearly seen now. Grease the lever which comes into contact with the cylinder as well. Use a high temperature grease or some WD40 or lubricating oil. Put the rubber boot back in place and reinstall the cylinder. Viola !! No slit in the rubber boot but more time spent.
One of the reasons for the rubber boot slit by the dealership could be the fact that this is a common reocurring problem so cutting the slit will enable you to lubricate the part more conveniently in future. But I would go for the 2nd method if I have the time to spare. Hope this helps you guys. Cheers.
Old Dec 17, 2003
Bigmac's Avatar
hey! thanks alot!!
guess you just posted a DIY...lol...good job
im sure that many members will find this usefull...at least, there's 1
Old Dec 17, 2003
Dr5D's Avatar
I will have to remember this if it ever happens to me!
Old Dec 17, 2003
tfnaaf's Avatar
BLDNPSI Mod
good job on the fix. one suggestion thou. dont use a petroleum based lubricant as it COULD damage the seal inside the slave cylinder and cause it to swell and then leak
Old Dec 18, 2003
ninerfan17's Avatar
thanks i will try that out
Old Dec 18, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
Also you might want to check the clutch return spring. Mine popes when you press it all the way to the floor. SO we went ahead and moved the spring up, solved my problem until it sliped right back down into the same spot. I lubed the cylinder, didnt work. Work pretty much told me that we would have to replace the slave cylinder and the return to solve my problem.
Jeff
Old Dec 18, 2003
rival559's Avatar
rival559 is an unknown quantity at this point
yea my clutch been pissing me off since last summer, whenever i press it i get a squeeeeeaking noise thats really irritating, oh well. thats why theres a radio in the car
Old Dec 18, 2003
GaryC17's Avatar
rival559 , Follow my DIY. I am very confident that it will solve your problem. Better than replacing your blown speaker cones.
Old Dec 18, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Yeah. . I get clicks. The dealership lubricated it up and it went away for awhile only to come back. So next time I stop in, I'll have them look at it again, lube it, see what happens. My guy at the dealership said that the grease isn't permanant, so it wears off. Who knows. I'll look under there, the dealership might already have a slit and I'll nail it with some WD40.
Old Dec 18, 2003
SPORT2087's Avatar
they paid for the repairs but it was not the only thing it was in for .........they replaced a total of 18 parts on my motor ,trans ,and a wheel bearing ........i guess in just hard on my car???????....then they lost parts to my car and didnt hook my amps back up or my neons ...
mjdiaz89
Jun 21, 2016 09:26 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
1khilari
Jul 9, 2015 08:12 PM
