Sponsored by:
Sponsored by: CARiD
exhaust smell ? high flow cat?
Old Dec 14, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
i wanna know how many people have high flow cats and if it smells ? if so what brand do you have and if not what brand ?
Old Dec 14, 2003
deciuss's Avatar
Boosted Auto
smell when your inside or out of the car?
Old Dec 14, 2003
Crackhead79's Avatar
Question Hi flow cats smell?
I agree, when I first put mine on it smelled funny too. I thought it would burn off, but now and then I still smell it. I think right now some of it is from my 91 octane in the tank. I know, my bad, had a brainfart, but until that is gone I will be dumping the unburnt fuel into the cat you know. Bummer, tell me if you find out what the smell is. I got my from Aimspot on ebay. He put perfect welds on it.
Also - I have a problem along the way with that cat, my engine check light comes on after I put the cat on. I disconnected the battery to reset the computer, but it comes back. I even checed to make sure nothing was loose and reset it again. What is it? Is it because I'm using the 91 octane right now? I'm going back to 87, lik eI should but I know the computer thinks I'm not burning right. Tell me what you all think it is. Laters
Old Dec 14, 2003
civicskater's Avatar
Chicks dig my scent
are your 02 sensors plugged in?
Old Dec 14, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
The cat seems to make the car run rich...I noticed it when I installed my HP header and high flow cat....After i got my VAFC II tuned, it cleared it up and leveled out my air/fuel mixture... As far as the the CEL that Crackhead is having, you need to properely install a o2 simulator.
Old Dec 14, 2003
I did tighten up the O2 sensor just fine. The plug is good too. Thanks for the kick in the head. Cwik
Old Dec 14, 2003
cwick187's Avatar
What are you talking about??? I'm not talking about the o2 sensor...I'm talking about a simulator to trick the ECU telling it that there is still a cat there. When you take the factory cataltic convertor out, it causes the the CEL to come on. That high flow cat is nothing but a straight pipe...
Old Dec 14, 2003
Sorry about that. Anything more I can do? Apologies all around.
Old Dec 14, 2003
Eeeeeeh's Avatar
Eeeeeeh is an unknown quantity at this point
My Headers gave my car a nasty smell but that's it. I have a hi flow cat also, but there wasn't a smell from that. I can only smell the header while I'm outside of the car
Old Dec 15, 2003
cwick187's Avatar
It's cool!!! All you need is the o2 sim to get the CEL to stay off as for the smell, it's just the car burning a little rich...It's not really that bad to burn a little rich, which means the ECU is telling the injectors to dump more fuel into the combustion chamber due to the higher amount of air flowing across the sensor. If it bothers you that bad, get a air/fuel controller (VFAC, AFAC) and have it tuned I hope this helped
Old Dec 17, 2003
Vafc or safc
Thanks bud, how well has your Vafc worked for you? how much did you pay? I'm waiting on the o2 simulator from wannaBfast. We'll see. Thanks man.
Old Dec 17, 2003
acidbaby's Avatar
The Beez Kneez
man its an 02 simulator
i gutted my cat and jusr put on a ceramic coated catback it really stincks because the exhaust has to get broken in.. as for the cat smell its totally normal.. the only thing that sucks is if you get a smart cop that pulls you over he will know you are running straight pipes
docmartin14
Jul 30, 2015 11:26 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Jerseygurl234
Jun 21, 2015 12:58 PM
MyCivic
Bolt-on Engine Performance
Dec 9, 2001 11:46 PM
1028CiViC
Nov 18, 2001 03:08 PM
