Attention Everyone With BODYKITS!
Old Dec 11, 2003
xX03EXx's Avatar
Sweetest Dude on 7th Gen
How did you guys jack up your car to change the tires or rotate them...It seems like my Kaminari sideskirts will get messed up if I use the jack the car came with. I feel so for asking this, but oh well
Old Dec 11, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
I had no idea that Kaminari sideskirts also get in the way of the jack. When I was taking my car apart for the winter I could not jack it up to take off the rims unless I took off my Xenon sideskirts first.
If someone has the asnwer I would also love to head it.
Old Dec 11, 2003
xX03EXx's Avatar
C'mon I couldn't have stumped all the car geeks out there hehe...
Old Dec 11, 2003
bigtime's Avatar
bigtime is an unknown quantity at this point
you can drive on to a couple pieces of 2 by 4 wood.
it will raise your car up a bit, and have no problem putting the jack underneath.....
Old Dec 11, 2003
halflife's Avatar
halflife is an unknown quantity at this point
i HAVE A FULL kaminari kit and have jacked my car up many times. My car is too low so I have to drive it up on a phone book first. I have a 2 1/2 ton jack that is bigger than the factory one. I ussually come from the front or rear of the car with the jack instead of the side. Your side skirt should not hit the jack points at all.
Old Dec 11, 2003
PunkingCivic's Avatar
I need TP for my bunghole
Get a car jack for lower cars.
http://www.harborfreight.com/cpi/cta...emnumber=47246
Or if you have a slightly sloped drive way
have the car half in the street and half in the drive
then you can get a normal jack under the car.
besure to chuck the wheels still on the ground
Old Dec 11, 2003
civic01vtec's Avatar
holy **** the n00b stole my answer......LOL
Welcome to the site BTW
if u use ramps, u have to use 2 x 4's to help get the car on the ramp w/o ruining ur bumper.
EDIT: nevermind, i see that u have been a registered member for quite a few mths.....post some more !!!
Old Dec 11, 2003
Indo784's Avatar
Indo784 is an unknown quantity at this point
I just went through this a few days ago. I have a Xenon kit and I didn't have to remove it to take off the rims. To do it, use the jack that came with your car. Make sure it is all the way down and slide it under your car so that it lines up with the frame, it should have a little indent in it so that the jack will fit there. Start cranking and the car will get off the ground, the back is much easier though cause all you have to do is put the jack on the axle in the back and crank. The hardest part is using the crappy jack that came with the car. Also, you can look in the manual and it gives you some places to jack.
Here is a crappy Diagram:
Old Dec 11, 2003
xX03EXx's Avatar
LOL ^ thanks man...I was just not in the mood today to be inventive i guess lol...pretty obvious answers but thanks a lot
Old Dec 11, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
i have that problem too.... what i do is use a pump jack 2.5ton one mentioned above and put it under the rear hook, middle of bumper thing or somewhere under there where it can support it, then i can slide the factory jack on the side or sides cuz i have 2.
edit: i have the kaminari kit as well
Old Dec 11, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i have G5 kit and a progress drop.
the only way to lift my car with jacks is to have someone lift the front end a bit via fenders and slide the jack under the front and use the front center jack point.
the sides cannot be jacked from a standstill, even with fender lifting.
Old Dec 11, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
cut 2x4's at 45 degrees nail together 2 high and 2 wide and ur good. my car is 3" off gorund and they fit perfectly under the bumper snug and raise it like 2.5"
riley
Old Dec 11, 2003
My xenon sideskirts tuck under my car and block off the spots where the jack should go.
junkyardguy
20
Sep 6, 2015 10:07 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
mrwhos
Aug 11, 2015 02:03 AM
carid
Aug 8, 2015 05:05 PM
breanna_17
Jul 21, 2015 04:01 PM
