JET V-FORCE not working right
Old Dec 10, 2003
slowcivic's Avatar
slowcivic is an unknown quantity at this point
I was just wondering if anyone has used the jet v-force without any problems. Supposedly it works for our cars. I wired it correctly, im positive i checked it like 50 times. I start the car and i can definetly tell a difference it revs alot smoother, more power, etc. It will be fine for about 30 minutes then my check engine light comes and i cant rev past 3500 rpm!!! as soon as it hits 3500 the fuel cuts off like its at redline. I have injen cai and a custom exhaust. Does anyone know why it is doing this???? Please help if u have any ideas Thanks
Old Dec 11, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
--> tech
Old Dec 11, 2003
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
this happens to me also but it takes a day or two for the light to turn on and sometimes it will do the fuel cut off thing
Old Dec 11, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I had a problem like that once and it was either my TPS or MAP sensor wires, make sure if you tapped into those wires, which I bet you did, that the connections are good!
Old Dec 11, 2003
did it work good after that
Old Dec 15, 2003
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
I have a similar problem with S-AFC there is no signal coming from the TPS when it is plugged in and when I try to accelerate it revs then all of a sudden it drops and then goes back up again..The only way my car works is if i disconnect the TPS and drive with it off....but then the engine idles at around 1100-1200 rpms but it still runs. I took it to honda and they said it was a short circuit somewhere in the dash and said it would be around $200 to fix, of course i didnt go for that so then i took it to a shop and they said it was a faulty TPS but i doubt it, since the only way to get a new TPS is by buying a whole throttle body directly from Honda, im gonna go to honda sometime this week and let them fix the short cicuit if thats waht it is
Old Dec 15, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I had JETChip re-program my ECU instead...the V-Force would not make a noticeable difference.
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
