Whats wrong?
Old Dec 5, 2003
kempster's Avatar
kempster will become famous soon enoughkempster will become famous soon enough
Whats wrong?
The other day i took off my 18 konig verdicts and put on my stock wheels. than as i went to drive, my car was wobbling. i noticed it was the front passenger wheel that was wobbling. the wheel is on tight, all of the other ones are fine so i have no idea what is wrong, any ideas
thanks in addvance
Old Dec 6, 2003
Eman's Avatar
Eman is an unknown quantity at this point
Could it be the ball joint
Old Dec 6, 2003
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
did your hub spacer come off with the konig you pulled off? If not then the wheel may not be seeded right. If it did come off with your aftermarket wheel just take the wheel back off and try remounting.
-Nic
Old Dec 7, 2003
Da1lyDr1ver's Avatar
it could also be a outter tie rod end. jack up the front of the car and try to wobble the wheel, if the wheel wobbles, it could be a tie rod.
Old Dec 7, 2003
MORG655's Avatar
MORG655 is on a distinguished road
All stock lugnuts? I actually had spacers on with my Konig Rated-Rs, and forgot to take them off when I put the stock wheels back on for the winter. The wheels seemed fine other than a slight wobble. Then I hit a pot hold and busted two studs. Make sure to check the spacer thing. Other than that....is it balanced right? Maybe a weight fell off while the wheel was in storage or somethin'. Check air pressure?
Old Dec 8, 2003
kempster's Avatar
i had no problem with the spare, i just put my konigs back on and now the steering wheel shakes. its not fun doing allthis in 30 degree weather and snow and ice everywhere
Old Dec 8, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
damn, i put my stocks on yesterday and am in love with the ride of the 15's. Sooo smooth. My 17's needed to be balanced anyways so at 80-90 i have alot less vibration!!
sorry about yours though.
Old Dec 8, 2003
Well although it may not be what you want to do let alone spend money on... go to an alignment shop that you can trust and talk to them about it. That'd be my next step if I were you.
Old Dec 9, 2003
kempster's Avatar
after a thorough test drive at low speeds the car seems fine, once i get upto around 50 the steering wheel starts to shake and gets worse as i go faster. i had my friend driving next to me and it was wobbling ever so slightly.
i don't think the tire needs to be balanced cause it was only off for a couple of days. i won't beable to get it to a shop till friday and i have to drive 100 miles each day which sucks and i have to find a shop that will actually work on my car since noone will touch it cause its to low.
Old Dec 9, 2003
well if your wheel is wobbling at higher speeds, i think its cuz its unbalanced. other members on this site posted the same problem and it turned out to be a balance issue.
Old Dec 9, 2003
kempster's Avatar
thats what i am going to get checked out but i doubt that is it. just about every wheel i put on has had this problem. i had my stock wheel balanced and it still had the problem. i hopew its something that simple and nothing is wrong with the front end
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
