strange idle and cel
Old Nov 30, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
does anyone have this problem?
The car idles at 1500 after driving. If you hold the brake and put the car in gear then put a load on it so that it's around 1000 for about 5 secs then it goes back to a normal idle. If you do not do this, after driving the car a few times, the cel light comes on and the car doesn 't run right until you reset the computer.
Old Nov 30, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
find out what code its spitting out...go to autozone or something and have them check it for you
Old Dec 1, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i have a small idle problem but for me its nothing like you and mine goes away after it warms up, urs could be a vacum leak somewhere, now if ur honda dealer is nice some will just hook up a obdII scanner and get the code print u out a paper and clear it, other than that most of them wont touch them if they have serious modifications, i was told this for like the 100th time saturday at my dealership, i just looked at them and said no ****, ive had two codes in my time, MAP and BARO sensor, which has to do with the equal atmospheric pressure to the MAP if they arent the same then it throws a code, but doesnt have the same effect as the MAP sensor code, a MAP code makes the car just fall flat as soon as it hits boost and the RPMs just go practically to zero
all in all get the code and its better to work from that
SimpleUser
Apr 24, 2021 02:54 AM
CBRBlaize
Jun 17, 2016 06:11 PM
Martinez8o5
Jul 31, 2015 10:58 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
