rsx-s rear sway on 03 LX?
Old Nov 17, 2003
reytito's Avatar
well i'm considering the DC5S rsx-s rear sway and Type R bushings for my 03 Lx....will it fit...hard to install, yoru experiences. thanks
Old Nov 17, 2003
Zzyzx's Avatar
Autocross Junky
Yes...... no..... its good for the street, but I need more for autocross.
IBTL
Old Nov 17, 2003
reytito's Avatar
whats best for autocross then?
Old Nov 17, 2003
Zzyzx's Avatar
Autocross Junky
I'd say one of the 22 mm (Preferably adjustible) bars with a stock front. Have to have that rotation......
Old Nov 18, 2003
reytito's Avatar
hmmm very interesting...
Old Nov 18, 2003
Zzyzx's Avatar
Autocross Junky
The issue with that is that the car may want to rotate a little too much for the average driver on the street. which can be dangerous.
Old Nov 18, 2003
robbclark1's Avatar
Retired suspension supermod.
hmm back end slipping out!! just slam the gas down and you should be good! hehe
Old Nov 20, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
yeh they install easy and the dc5 is a type r btw
Old Nov 20, 2003
robbclark1's Avatar
huh?
The dc5 is just an RSX. The RSX/RSX-S have 19mm sway bars while the type R has a 22mm sway bar.
Old Nov 20, 2003
DC is the chasis code ie integra in japan not actually an rsx the 5 signifies the type r not a type s
Old Nov 20, 2003
robbclark1's Avatar
DC5 is the code for ALL RSXs
Old Nov 20, 2003
taz757's Avatar
DC5 is the RSX and RSX-S. DC5R is the Integra Type-R. EM2 is the Civic Coupe. EP3 is the Civic hatchback. ES2 (or ES3) is the Civic Sedan (not too sure on this one).
Old Nov 20, 2003
robbclark1's Avatar
yes it will fit...you can't put Type R bushings on your Type S bar. The type R bushings are for a 22mm bar. If you want better bushings get the ES 19mm sway bar poly ones. It is an easy job.
here is a DIY
http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
Viczhou
Sep 2, 2015 07:55 PM
