rsx-s rear sway on 03 LX?
well i'm considering the DC5S rsx-s rear sway and Type R bushings for my 03 Lx....will it fit...hard to install, yoru experiences. thanks
Originally posted by jdmb16ahatch
yeh they install easy and the dc5 is a type r btw
The dc5 is just an RSX. The RSX/RSX-S have 19mm sway bars while the type R has a 22mm sway bar.
DC5 is the RSX and RSX-S. DC5R is the Integra Type-R. EM2 is the Civic Coupe. EP3 is the Civic hatchback. ES2 (or ES3) is the Civic Sedan (not too sure on this one).
yes it will fit...you can't put Type R bushings on your Type S bar. The type R bushings are for a 22mm bar. If you want better bushings get the ES 19mm sway bar poly ones. It is an easy job.
here is a DIY
http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm
here is a DIY
juror
Suspension DIY
Jul 30, 2019 03:28 AM
redcloud
Sep 7, 2015 01:45 PM
