HELP! Anyone know anyone from Honda Service prefrebably not Formula Honda.
Old Nov 17, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
So my car got hydrolocked and I brought it to Formula Honda, they charged me and said its my fault, fine thats ok.
The check engine light is on and when I shift it only shifts into second and sometimes third gear and when I put the car in park, I cant get it out of park, it is locked, I have to let the car sit for a minute or too, turn it off as well and try it again untill I can shift into drive.
So Formula Honda says that its not related to hydrolocking which is good because then its a whole another problem not of my own and it could be covered under warranty but since after bringing in the car with hydrolocking they are somewhat biased on what is causing the problems, mainly saying its my fault.
Sooo I am planning to bring it somewhere else hopefully to get it covered under warranty, anyone know any other dealerships?
Old Nov 17, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
try action honda
Old Nov 17, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
Yeah, Action Honda's service guys are pretty nice. I got a CV boot problem before, and even though my car was lowered (which would void all suspesion warranty) they offered to look away and replace the outer CV boot for me ($400 part) under warranty.
Try and just bring your car into there and have them look at it, without telling them about the hydrolock, of course. Try to speak to Hubert, or bring it in when he's there. He's generally more coorperative than Peter.
Old Nov 17, 2003
R1Style's Avatar
Ok... I'm confused. You think you hydrolocked your engine and you're having trouble shifting?
Just to let you know... if you hydrolocked your engine... that means you injested a large amount of water causing your engine to sieze. If that was the case... I don't think your engine would even turn over.
Judging from what you said, I'm assuming your engine runs so it's probably not hydrolocked.
Also, about your shifting problems, it has nothing to do with your engine. Get your tranny checked.
Old Nov 17, 2003
vicLX's Avatar
<--That really is ME
Action Honda in Kingston is a good place to go...
Old Nov 17, 2003
TeLLy's Avatar
Yes, it's an Acura EL
It WAS hydro'd but he got it fixed. Ya know, I'm wondering if maybe the ECU would have anything to do with the loss in tranny cooperation. Could it be maybe it still thinks the car is in deep doo doo and as such is in some kind of "safe" mode? Just a thought. When it comes to anything in the engine bay I'm a friggin idiot.
Old Nov 17, 2003
MSoft's Avatar
Best thing to do anyhow is to take it to Action Honda and tell them all the problems (not the cause) and have them thoroughly check your car. If there were big no no's discovered from Formula Honda it'd be in the service database... So have them check it, but check with you before doing any work or ordering any parts.
Old Nov 17, 2003
netcbc's Avatar
You're correct Telly, thanks for clariyfing, where is Action Honda?
It could be the engine because I read how someone got the exact same problem as me and they had to replace their throttle body, some senors and reset engine codes, i let formula know about that but i think they just ignored my *** thinking i dunno what i'm saying....
Old Nov 17, 2003
vicLX's Avatar
Action Honda is located on Kingston Rd. Between Galloway and Morningside
good luck!!!
Old Nov 17, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
try pickering honda too, they are very good.
Old Nov 18, 2003
netcbc's Avatar
w0ot so lucky, Formula Honda didn't screw me, they replaced some things on warranty, came out to like 1 grand, replaced throttle body and ecu... now i finally finally have my car back
Old Nov 19, 2003
Hachiman's Avatar
Hachiman is an unknown quantity at this point
Action Honda SUCKS!!! go to pickering Honda.
Old Nov 20, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
I've had 2 people complain about service from Formula Honda now.
I'd never go there.
Old Nov 23, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Don't even bother with MARKHAM HONDA. Worst dealer!
Old Nov 23, 2003
Glad you got it fixed. Does it run as good as before? Your sedan is one of my favorites
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
ImmortalEX
Oct 31, 2001 10:00 PM
