vafc-2
Old Nov 17, 2003
2k2civic's Avatar
vafc-2
does anyone have a 2002 civic ex with i/e/h 2.25 inch piping and a vafc2 with it being dyno tested and if yes can you please put vafc2 settings and is the setting for car select (4/upright/3 or 4/upright/2)
thanks
Old Dec 28, 2003
red02's Avatar
red02 is an unknown quantity at this point
im in the same damn boat with you and it is (4 up 3) thats what the manuel says, and does it work ..... of course not. maybe there are specific settings to avoid cylinder or fuel cut because once it is set i can red line every gear... but when i come to idle and then pick back up it wont go past 3900. i checked the wiring numerous times... its all correct to the diagram. does yours work ?
Old Dec 29, 2003
JDMsicvic's Avatar
JDMsicvic is an unknown quantity at this point
get it tuned professionaly....just b/c somebody has your exact parts and everything...everybodys numbers are different...trust me i tried.....and if anything it will mess up your car.......its worth the 100$ or so......you will be happy....
Old Dec 29, 2003
red02's Avatar
just curious for anyone who might know but is the ecu wiring the same for 01 as 02? it has to be right? same car. i read on here somwhere that it works with 01 and not 02
Old Dec 29, 2003
civic01vtec's Avatar
the only way to do it is to dyno tune it
Old Dec 29, 2003
CarbonFly's Avatar
The correct setting is 4/up/1
Old Dec 29, 2003
red02's Avatar
4 up 1 ? the manuel says 4 up 3 !!!!! maybe this is why yours works and apexi is wrong. if you are right thank god, going to try this now !!!
Old Dec 29, 2003
ImportRacer2123's Avatar
K20 Member
Let me know if it works
Old Dec 29, 2003
red02's Avatar
will do stand by !!
Old Dec 29, 2003
K20 Member
Go try right now or i might have to! This should remove that weird 4,000 rev limiter correct?
Old Dec 29, 2003
red02's Avatar
ok so that rules out 4 up 1 and i tried type 2 while i was at it same thing. that really would not make a difference right? because it is the area of the rpm band where your vtec kicks in ( low reving medium and high reving) do you ever stop and ask why do i waste so much time and money on a lost cause ? im starting to ... fly whatever you did different more power to you, just wish i knew what it was.
Old Dec 29, 2003
red02's Avatar
as you can tell iv'e devoted all my time to this thing ... i eat sleep and breath 7thgencivic forums... im going frekin bonkers... whats different about my 2k civic than everyone elses
Old Dec 29, 2003
K20 Member
**** man. this sucks i guess im going to fork out money to have my VAFC II work and run properly.
Old Dec 30, 2003
red02's Avatar
well i got raped for 40 bucks today to have my shop take the negative off and reset the check engine light. hope you get somthing figured out i havent
Old Dec 30, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
cant say it any better, u want the best performance...spend the money
Foffie
Mar 25, 2009 06:14 PM
nighthawk1903
Feb 19, 2006 02:16 AM
ncirom2003
Engine Swaps
32
Sep 19, 2005 05:44 PM
ncirom2003
Sep 6, 2005 06:13 AM
Cocky
Aug 10, 2005 03:31 PM
