Is it a resistor problem
Old Nov 5, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
If my halo ring isnt working, could it be the resistor isnot strong enough. so what if I went to the Shack, picked up a bigger resistor, and just wired it into the wire coming out of the headlamp assembly? Wouldnt that solve the issue?
Old Nov 5, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The halo isn't working because it is not hooked up properly or it is burned out... a resistor isn't going to fix it. check your positive and ground connections...
Old Nov 7, 2003
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
Resistor not strong? You know all a resistor does is create resistance to DC current. If it's wired in series you'll get more voltage out of it, and it'll dissipate more heat, which could be bad. With electronics, it could be any number of things. Bad components, bad wires, shorted wires, bad connection, incorrect installation, or even just a bad product. Look at all that wiring and make sure there isnt any exposed copper. Then triple check all your connections. And finally, check to make you the halo ring isnt burned out. They're LED's right? If so, you can go back to RadioShack, buy some and solder them in yourself, if you know how.
JAMorganIII
23
Jul 4, 2015 11:52 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
