painted pinstripe?
Old Nov 4, 2003
painted pinstripe?
I really wanted to remove the pinstripe. It looks bad, but it seems that someone actually painted it on! Is there something that will take it off? Scraping doesn't work.
Old Nov 4, 2003
Zzyzx's Avatar
Autocross Junky
ushually a paint shop wil take 2000 grit sand paper and sand it off then polish the area back to a shine.
Old Nov 5, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
a buffer could get it of... i could take it off inlike 5 minutes..LOL.. go to a paint supply store and by rubbing compound.. use it VERY sparingly.. r8b over the stripe.. it will come off with that stuff. buy the 3m... also, amake SURE you use a polish and waxz after that.. even clay and use a swirl remover if you can.. it is har on the paint, but best way to get it off..
Old Nov 5, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
I had mine removed before I picked the car up.
Old Nov 6, 2003
I tried rubbing compound and it didn't work. I stopped after that cause I didn't want the rest of the paint to get ruined. It almost seems like they baked it on at the factory. I can't even scrape it off with fingernails. Any more ideas?
Old Nov 6, 2003
cdmx's Avatar
they Painted it on!!? are you sure!! did it come new from honda? if so it should be a sticker..
Old Nov 6, 2003
It's def not a sticker, or I would be able to peel it off. It looks like paint, cause when the two lines overlap it gets thicker. I'm guessijng sandpaper is the only way, but I don't want to ruin the paint.
Old Nov 6, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
honda has painted their pinstripes since forever and wouldnt take mine off either
Old Nov 6, 2003
2 words: paint job...
Old Nov 6, 2003
I actually got some wet/dry sandpaper (1500 grit), but couldn't go through with it. I'll just leave it.
Old Nov 6, 2003
dirtySAMURAI's Avatar
I log in from time to time
hehe I got one that was a sticker. So freaking hard to remove though. I washed my car and the sticker was all slippery and cracking...so it came out in millions of little slices.
Old Nov 6, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
if u use the buffer too long it could remove the clear coat couldnt it?
Old Nov 6, 2003
cdmx's Avatar
Hey im not sure if this would work, it may take a while. But how about a dremel with a polishing bit.
Old Nov 7, 2003
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
i think its a dealer option, i dont think honda puts on pinstripe. i dont have any. and i think it makes the car look old. like something from the 80s, cheap coolness if you know what i mean. hahaha. be like homer, get some speed holes too.
Old Nov 7, 2003
Gee thanks guys. Make me feel even worse now that I have to live with it
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
