Shaking steer
Old Nov 3, 2003
agungmeth's Avatar
agungmeth is an unknown quantity at this point
Shaking steer
Hi,
Last week, I installed my eibach pro kit. When I driving at highway, at approximately 80 mph, I feel my wheel steer is shaking. What service do I need to fix it? One more question, Do I need camber kit eventhough the pro kit doens't provide too low ride? (1" all sides)
Thanks guys.
Old Nov 3, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
mine does same thing.... im getting camber kit soon but i think its alignment.
riley
Old Nov 3, 2003
agungmeth's Avatar
so....you did something at 80 mph and yur steer shaking?
Old Nov 3, 2003
civicvtec1ps's Avatar
Search and Learn
did you ever get realignment after spring install? you should not need camber kit with prokit. only drops 1"..
Old Nov 3, 2003
dj02's Avatar
u need to get a alignment done to ur car. and no u dont need a camber with a 1' drop but it wouldnt hurt to get one if u wanted to also.
Old Nov 3, 2003
robbclark1's Avatar
Retired suspension supermod.
First get a camber kit, then a thorough alignment. If that doesn't work then you need your tires rebalanced. Get the balance done well not at a crappy firestone or something...get a good electronic balancing.
Old Nov 3, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
you should get the camber kit, because i used to have the pro kit and it ruined my tires, they were so bold around the inside edge I am lucky i didn't have a blow out, get the camber kit, then get the alignment.
Old Nov 3, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I had my alignment done at Sears and if it still has a problem afterward they do it again for free within two or so months I think they said.
Old Nov 3, 2003
Mr.Modify's Avatar
are your nuts tight errrr...i mean are your lug nuts tight? in other words i mean torqued because when i didn't torque mine after taking off my tires one time my steering wheel always shook while driving!!
Solo Flow
Oct 4, 2015 07:52 AM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
