Garrett Turbo and SF Manifold
Old Oct 25, 2003
abmerop18's Avatar
Jam out with your clam out.
will this garrett turbo bolt on to the SF manifold? it is from my friend's eclipse. he is upgrading and said he could give me a good deal on this. thanks for the help.
Old Oct 25, 2003
abmerop18's Avatar
another pic
Old Oct 25, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
That looks like a T25. SF manifold uses a T3 flange. It will fit on the HKS manifold, which is what i am using. I have a thread on my turbo setup here. click
Old Oct 25, 2003
EDIT: actually it doesn't look like it has a T25 flange....I'd say go with something else besides that.
Old Oct 25, 2003
abmerop18's Avatar
what does it look like? i can get this for $250 or so from my friend, so it is a great deal and works fine if i can get it to fit.
Old Oct 25, 2003
Originally posted by abmerop18
what does it look like? i can get this for like $250 or so from my friend, so it is a great deal and works fine if i can get it to fit.
Forget that man. Too much for something that looks like it will require quite a bit of fabrication to fit on a manifold. Ask your friend what kind of flange it has on it. It is really best to not go half *** on a turbo setup; try to buy things you have no question will fit, or you'll end up spending alot of money. Oh and btw, $250 is alot for a used turbo. I got my turbo for $180, its a Garrett GT25 dual ball bearing turbo, it was used for less than 5000 miles.
Old Oct 25, 2003
abmerop18's Avatar
did u build a custom turbo setup? how much did it all end up costing you in the end? what kind of turbo would you recomment i get, if i dont get this one from my friend?
Old Oct 25, 2003
My setup is currently being built....it is as follows
HKS Turbo manifold - $260
Garrett GT25 turbo - $180
Greddy E-Manage - $250
Greddy optional injector harness - $25
Greddy optional ignition harness - $31
Greddy E-manage support tool - free
1 440 CC injector - $50
Greddy weldon injector plate - $28
Johnnyracecar.com intercooler (31x6x2 and fits perfect) $249.95 shipped
HKS Super Sequential BOV - $185 shipped
HKS Super Sequential BOV flange(steel) - $25 shipped
Used Greddy EGT and Boost Gauge (peak and warning) $250 for both
8psi baseline actuator - $15
Mild steel intercooler piping - $140
Couplers and clamps $60
Oil lines and fittings $90
2 3" mildsteel donut bends and various other 3" O.D peices, with 3-bolt flange, and 4 bolt exhaust flange for downpipe - about $110 give or take
The total right now is approximately $1700 or so. I expect to finish the project under $2000. I'm doing all my own fabrication in my workshop, and using a welder at a family members house.
I like the GT25 for its fast spooling capabilities. But don't count on finding another used one, they are few and far between. I recommend a Garrett T25BB or something similar. They lack massive top end power but make up for it down low.
Old Oct 25, 2003
boo's Avatar
boo
boo is an unknown quantity at this point
i'm curious about emanage? does it require alot of tuning? can you replace all 4 injectors or does it only allow to add an additional injector. also are you using one of those missing link check valves in your setup?
Old Oct 25, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
You can replace all of the injectors but u must customize your fuel rail. He chose to go with an additional injector setup which is simple and very effective.Yes the e manage does require tuning
Old Oct 25, 2003
EnProceso's Avatar
dude where at? i can only find it for like $210 w/out s&h!
Old Oct 26, 2003
www.hondadriven.net - great guy!
Old Oct 26, 2003
abmerop18's Avatar
the model number of the turbo is 2tp 22001. do you know anything about this one? any specs?
SammySC
121
Apr 7, 2017 07:43 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
