Garrett Turbo and SF Manifold
will this garrett turbo bolt on to the SF manifold? it is from my friend's eclipse. he is upgrading and said he could give me a good deal on this. thanks for the help.
Originally posted by wannabeblown
That looks like a T25. SF manifold uses a T3 flange. It will fit on the HKS manifold, which is what i am using. I have a thread on my turbo setup here. click
EDIT: actually it doesn't look like it has a T25 flange....I'd say go with something else besides that.
what does it look like? i can get this for $250 or so from my friend, so it is a great deal and works fine if i can get it to fit.
Originally posted by abmerop18
what does it look like? i can get this for like $250 or so from my friend, so it is a great deal and works fine if i can get it to fit.
did u build a custom turbo setup? how much did it all end up costing you in the end? what kind of turbo would you recomment i get, if i dont get this one from my friend?
My setup is currently being built....it is as follows
HKS Turbo manifold - $260
Garrett GT25 turbo - $180
Greddy E-Manage - $250
Greddy optional injector harness - $25
Greddy optional ignition harness - $31
Greddy E-manage support tool - free
1 440 CC injector - $50
Greddy weldon injector plate - $28
Johnnyracecar.com intercooler (31x6x2 and fits perfect) $249.95 shipped
HKS Super Sequential BOV - $185 shipped
HKS Super Sequential BOV flange(steel) - $25 shipped
Used Greddy EGT and Boost Gauge (peak and warning) $250 for both
8psi baseline actuator - $15
Mild steel intercooler piping - $140
Couplers and clamps $60
Oil lines and fittings $90
2 3" mildsteel donut bends and various other 3" O.D peices, with 3-bolt flange, and 4 bolt exhaust flange for downpipe - about $110 give or take
The total right now is approximately $1700 or so. I expect to finish the project under $2000. I'm doing all my own fabrication in my workshop, and using a welder at a family members house.
I like the GT25 for its fast spooling capabilities. But don't count on finding another used one, they are few and far between. I recommend a Garrett T25BB or something similar. They lack massive top end power but make up for it down low.
i'm curious about emanage? does it require alot of tuning? can you replace all 4 injectors or does it only allow to add an additional injector. also are you using one of those missing link check valves in your setup?
Originally posted by 18secQuaterMile
dude where at? i can only find it for like $210 w/out s&h!
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
