intake manifold vs stock port and polish
Old Oct 17, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
i wanted some people views on which one they think would be better an intake manifold with shorter runners or with longer ? im looking to get one for my 95 civic and dont know which one to get one is a custom intake manfold that looks like the obx intake manifold a picture is attached below and the other is a stock manifold which has a longer runners but is ported and polished by gude i dont have pictures of the gude yet but will put up later
Old Oct 17, 2003
Ouse's Avatar
Ouse is an unknown quantity at this point
i would say the obx. arent our intake manifolds made of plastic? i got into an accident a while back i think i might have craked mine. im gonna check it out this weekend.
Old Oct 17, 2003
mclean987's Avatar
yeh the 7th gen are plastic but im talking about a 95 civic which isnt plastic.
attached is a picture of the stock port and polished manifold which one do people think would be better for performance ?
Old Oct 17, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
he said 95 civic.....
i would go with the port&polish
Old Oct 17, 2003
mclean987's Avatar
and here is a pic of the obx intake manifold
Old Oct 17, 2003
mclean987's Avatar
is it just me or does the first manifold look the same as the obx manifold ? the guy never said it was an obx, heres another view
Old Oct 17, 2003
djmota's Avatar
what are the mods on the 95 ...cam, head work ect??
if none then i would say go with the ported original.
If a cam, cam gear, throttle body headwork ect are in the near future than i would say go with the aftermarke intake. But i would not trust obx to make a good manifold, i am thinking more along the lines of skunk2 or something. oh yeah they do look different.... not much of a difference in runner length.
Old Oct 17, 2003
opto_isolator's Avatar
Some quick info about intake manifolds:
Shorter runners (OBX) will allow the manifold to flow better. That means better top end power. Longer runners allow for more lower end power, due to something called "port tuning."
If you have adjustable cams, or can adjust your timing in other ways, the OBX will work great. If your car is stock, than the PnP'ed stock manifold would probably be better. If you install an OBX withough doing anything else, you'll probably lose low end torque / power......
Old Oct 17, 2003
mclean987's Avatar
thanks for all that info guys
Old Oct 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I wish the KMS manifold for the 7th gens would actually produce power than
rob you of power!
Port and polish is the way to go.
Old Oct 17, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
dont worry, Catalyst is making a manifold for us 7th gens!
Old Oct 17, 2003
mclean987's Avatar
so the kms intake manifold for the 7thgen doesnt make any power ?
it actually makes you lose power ? has anyone dynoed it ?
can someone post a pic ?
Old Oct 17, 2003
jwalker87's Avatar
Bodacious Member
some people say it takes away power, and others say it gives no gain...either way, not worth it. Catalyst is developing a new manifold which will have proven dyno gains.
Old Oct 18, 2003
mclean987's Avatar
ok tell me what you think here is my setup can the obx give me good bottom and top power if i tune my car right ? more than the stock port and polished intake manifold ?
i have a 95 civic hatchback with a jdm d15b 1.5 sohc vtec with a d16y8 port and polish head zex cam, stage 2 clutch,cold air intake, header,exhaust,cam gear and mugen ecu vtec ((4700 rpm limit 10,000)) gonna add some a dual core radiator, a 7lb flywheel and high compression pistons next week i already have them. i might have to get a d16block for pistons to work to raise the compression to from 9.6 to 13.0
lowered with tanabe springs and tokico shocks, 4 stabilizer bars and 15n inch si rims
what should be my next mod? nitrous ? i know i cant run turbo on such high compression but how about a supercharger ?
Old Oct 18, 2003
civic-king's Avatar
dh racing makes manifolds for 7th gen......if you don't want to wait for "development".....
Old Oct 18, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
Do you know when its post to be out?
Old Oct 18, 2003
mclean987's Avatar
so what should my next mod be ?
Old Oct 18, 2003
cambo's Avatar
I wish I was asian
nitrous, turbo, and super are all forms of FI. i wouldnt run a supercharger on 13:1 compression.
Old Oct 18, 2003
mclean987's Avatar
yeh i know that they are all forms of fi but i heard that nitrous loves a high compression ration dont know how true this is
Old Oct 19, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
If you run it with real high octane fuel like race gas you might get a way with it...but your going to have to run serious fuel for 13.1 you can't run that on pump gas.
Old Oct 20, 2003
mclean987's Avatar
so i cant run 93 octane with retarded timing and proper tuning ?
Old Oct 20, 2003
xblkcivicx's Avatar
I don't have the conversion chart infront of me, but im pretty sure your going to need to runhigher octane than 93 even with the retarted ignition timing...Find a compression/octane calculator on the web, it will tell you all the conversions. Personally i think it will knock
Old Oct 20, 2003
mclean987's Avatar
i heard from some guys who have experience and thye told me that i can run 13 compression with 93 octane and proper tuning and retarted timing because they did it already
Old Oct 20, 2003
xblkcivicx's Avatar
go for it then
Old Oct 21, 2003
xblkcivicx's Avatar
If you run 13:1 compression with the proper FUEL (race gas, or methanol) with advanced timing then you will make more power. If you run 13:1 compression and RETARD your timing...your defeating the purpose, they cancel each other out it's going to run like *** and not have full potential. but you are right you will be able to run pump gas on it.
You want to run your ignition timing as advanced as you can before you rattle the motor....advance...advance..advance..and then when it rattles, bring it back a little bit untill it stops rattling. then you have perfect timing.
IF YOU RUN HIGH COMPRESSION YOU NEED TO RUN HIGH OCTANE!
That's all there is too it...
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
92hatchbackcx
Jul 7, 2015 08:23 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
