Too low of drop....cant lift car!!!
Old Oct 9, 2003
dru106's Avatar
ThE CoRRupToR
Angry Too low of drop....cant lift car!!!
I have a 1.75" drop and I was havin trouble goin to places to get my oil changed. And I was thinkin how the heck u guys wit a 2"-2.5" drop hoist your car up? I just bought a hydrolic jack and it just barely fits underneath.
Old Oct 9, 2003
Marion26's Avatar
Marion26 is an unknown quantity at this point
Dude I have the same problem as you do I have eibach sportlines and it's getting to my nerves recently can't drive to steep angles and all the s*&t lowering your car does. I have my oil changed in a shop that has a lift specifically for dropped cars my oil changes cost me $50 a pop I use Royal purple oil.
Old Oct 9, 2003
Civicly02's Avatar
just do it your self and get a small cheap jack. Have a homie lift your car up a little bit through the tire wall adn you will be able to jack up the car
Old Oct 9, 2003
Mr.Modify's Avatar
yea i went to this car wash cause i gotta free one and i was all asking questions like do you think this will clear and i was watching them and telling them to go slow and **** !! lol friggin funny!!
Old Oct 9, 2003
flotsamm's Avatar
I think some peeps drive up on blocks of wood, then when its up high enough they use a floor jack and jack stands. Or some use the stock scissor jack.. dunno. I have Eibach Sportlines but I can get my 3-ton floor under my car without any problems.
Old Oct 9, 2003
GreenNVicious's Avatar
Newbie
be ghetto, i learned the "two brick" trick hehe, just roll that up on 2 bricks
Old Oct 10, 2003
djmota's Avatar
2x4's work for me. my jack sits pretty low also
Old Oct 12, 2003
GrayGhost's Avatar
Welcome To Prime Time, BITCH!
GrayGhost is on a distinguished road
At the dealership that I work at, sometimes we have to take boards and such to streach out the ramps on the lifts in order to get lowered cars on there. But there are some oil change places that don't even require that. I used to go to a Texaco X-Press Lube. In their bay they don't have lifts for the oil changes, they go down stairs under the bay and open the grates under your car. That way they are under the car with out the trouble of lifting it.
Old Oct 14, 2003
sexcivic2k1's Avatar
just do it yourself, or find a shop like "gray ghost" said.. you'll save lots of money by doing it yourself, like 10-15 bucks per oil change
Old Oct 14, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
my car from bottom of bumper to ground is 1 and 7/8" which sucks because thats the height of one 2x4 so i have to drive up on 2, 2x4's then put 2x4's in front of those and drive up and then i can finally stick my jack in the wheel well and teeter tot it around to the jack spot. it takes like 15 min to drive /jack up the front of car... or if i go to place where u drive into bay where they walk down stairs i have to take off front bumper and unhook fog lights....sucks to be me sometimes..
riley
thisis with 1.4 drop w/ my erebuni kit... once i get 19's im droppin on B&G 3" so im gonna liek kill my kit i think but it'l mos def look good......:-)
Old Nov 10, 2003
Elite's Avatar
Elite is an unknown quantity at this point
I bought ramps at kragen they lift the car like 3/4 of a foot! or more! really sturdy plastic, then I just use a hydrolic jack from there
Old Nov 10, 2003
Elite's Avatar
check my ride lol you'll see
Old Nov 10, 2003
Elite's Avatar
oh yeah i forgot to tell you i take off my bumper beause the full replacements are really easy.
Old Nov 10, 2003
Voiceofid's Avatar
End Bringer
get a low profile shop flood hydrualic jack, if you can afford one
they slip right under my car
Old Nov 10, 2003
slicksivik's Avatar
where do u put the jack at. i mean i got a hydraulic one and i tried to jack my car up and it jacked up like a foot over my rim and it was sitll on the floor, so i stopped and took it somewhere to get it done. i didn't kno why it wasnt going up. i cant put it right on the corner where ur suppose to cuz my body kit like curves in near the wheel well where the point is so i had to move it down further. any thoughts?
Old Nov 10, 2003
4bangin's Avatar
for oil change places, ask them to back your car in from the exit side of the stall, it usually will go then. also, for the jack, either lift up on the car and have someone slide the jack into position or drive up on a 2x4 and then slide the jack under.
Old Nov 11, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
if you can't fit the jack under the jack points on the sides of the car, then you can jack up your car by placing the jack in the dead center of the car (front or back) and sliding it in under the part where the control arms meet in the center, but use a block off wood to buffer the chassy and the jack. Once the car is up high enuf, place jack stands on both sides of the car and pull out the jack. This worked for my sway bar install. I hope i didn't confuse people, cause i dunno if there is a term for that part of the car. ^_^
Tedverseti
Apr 23, 2020 01:45 PM
mikemc422
Aug 9, 2018 05:41 PM
mattdoc
Mar 14, 2017 12:10 PM
dooner24
Apr 14, 2015 07:51 PM
ImmortalEX
Oct 31, 2001 10:00 PM
