How long should engine swap take?
Old Oct 7, 2003
mcwoowoo's Avatar
mcwoowoo is an unknown quantity at this point
I left my car at a shop in San Jose,CA called BlackTrax to do my K20A2 swap. I wonder if any of you know how long should this kind of swap take?
They started on last friday and when i called them this morning, they told me that they were working on the steering lines and stuff and they haven't got to putting the engine in yet.
BTW, i'm doing the hardest swap ever (i think) because my civic is a LX auto tran, and i'm converting it into stick shift and swaping the engine. Don't know when will this be done.........
Old Oct 7, 2003
hoho's Avatar
hoho is an unknown quantity at this point
damn...u r lucky...i want that swap and i also have lx auto tranny...haha...u r rich!!! good luck
oh i dunno how long it'll take....i dunno much about cars
Old Oct 7, 2003
oh ****.. that's a big *** swap.. lol an lx auto to a stick k20a2... nice tho.. i just felt like complimenting.. i dont know **** about swaps..
Old Oct 7, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i dont think its all that much harder to do just because its a auto even if your civic is a stick you still need to swap the tranny. my civic is a auto and i will consider doing a swap in a year or 2.
Old Oct 7, 2003
Jodster's Avatar
Post Whore General
Well if they know what they are doing it should only take them a couple of weeks. There is alot of wiring to do. Not to mention the Key Code problems.
Old Oct 7, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
i dunno about engine swaps, but it seems to me as if all shops, even normal body repair shops or wutever take their time wen doing anything. either because they want to be careful, or sometimes just to charge more money or sumthin. speed image in san jose (never go here, bad plaec imo i only went ehre to buy light bulbs) told my friend it wud take 1-2 hours to install his intake, my friend and i instaled it in like 30 minutes.
i dont kno how engine swapping goes, but i bet if they realyl wanted to finish it quickly, they cud intsall it a lot faster than it will really take them if they realyl spent time on it working hard and crap. but i guess its better to go slow and make sure every thing is right, better safe than sorry.
Old Oct 7, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
from what i know, usually it takes a week or 2 depending on the shop. I've known shops that swapped in a b16 into a older gen civic over night ( 2 days total). I think the k20a2 swap may take up to 2 weeks...give them time man...don't rush the shop, let them take as long as needed...this is your life on the line here, don't take it too lightly. They do a good job, u're life will be secure, and u'll have a kickass car too...if u rush em, they much do a iffy job, and you might find urself in an accident in the near future. Good luck man!
Old Oct 8, 2003
mcwoowoo's Avatar
you know, going from auto to stick with k20a2 is hard, cuz there's a bracket that connects the engine to the engine bay is totally different from the stick civic engine bay. and it's not inculded in the hasport mounts, so the shop had to special order it from honda dealer.
Old Oct 8, 2003
mcwoowoo's Avatar
i don't know what they are going to do with the wiring and stuff.
hasport suppose to have wiring harrness set for k20 swap, but somehow they haven't put it on their website yet.
Key Code is very easy to fix, i just order the Hondata ECU flash, they will clear and reset the key code.
Old Oct 8, 2003
cdmx's Avatar
there's a guy on here who has been waiting over a month...not sure whats up with him though
Old Oct 8, 2003
mcwoowoo's Avatar
here's a list of parts i've put in for the swap so far
K20A2 engine
DC 4-2-1 header
Injen SRI
Hondata
Hasport engine mounts
Custome dual exhaust
5zigen Copse 17' w/ yokohama es100 215/45/17
CF hood
how fast can my car go with this kind of setup?
Old Oct 8, 2003
kafyn722's Avatar
quick question.. how much does all that cost. just the k20 swap is all i want.. how much?!?!
Old Oct 8, 2003
mcwoowoo's Avatar
i got a really good deal for the engine, it only has 127miles on it and cost me 3500. the engine came with subframe, ecu, axles, tran, and wiring harness. then i spent 200 on civic paddles and rsx shifter assmebly. 650 on hasport engine mounts, 720 on hondata ecu flash(must flash ecu to match the key code), there are some other small parts that i don't know how much yet ( such as fuel lines, steering pump, and etc. ) and finally, the labor cost about 1700
so if i'm only doing the engine swap, the total is about 7000
Old Oct 8, 2003
mcwoowoo's Avatar
i'll keep you guys informed about my swap, if you have any questions regarding the details, try me. i might be able to answer them. or i'll ask the shop for you guys
-good luck
Old Oct 8, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
my swap took about 2 months to do. There was a lot of little stuff that you dont even think of when you are doing it that come up and hold you back. I know it took HASport a weekend to do the swap, and that was from auto to stick...but they knew what they were doing, and they had a junk yard right accross the street from them. Good luck with your swap, question...why did you get the short header?...you might get like 2 whp out of it. In some cases, it has been proven to actually take away hp. Dont ask me how, i just read the dyno charts. Are you doing the 5-lug conversion? If not, make sure to get 2002 Civic Si axles, i tried the GSR ones, they dont work. Keep us updated.
Old Oct 8, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
ur getting ur car done at blacktrax? i got a quote from them and they wanted 4500 for the type s eninge and 1600 for labor! that didn't even include the motor mounts! well..keep us updated..i wanna see if black trax does a good job.
Old Oct 8, 2003
mcwoowoo's Avatar
thanks for the tip~
my engine didn't come with a airbox, so i thought might as well get a short ram.
and my car will still be 4 lugz, but i'm not sure which axles they will be using though.
Old Oct 8, 2003
mcwoowoo's Avatar
from my knowledge, they've never done a k20a2 swap yet.
when i went to them, they asked me to find most of the parts for them. so in my case, i ordered most of the big parts and have them shipped to blacktrax, and they took care of the small parts (steering pump, axles and stuff)
Old Oct 8, 2003
mine didnt come with an air box either...so i got a CAI, its the best with other mods like Hondata, TODA, and so on.
If you are keeping the 4-lug like what i did, the ONLY axles that work are the 2002 Civic Si axles. From dealer they are about 2 grand...yes really, 2 grand. But, you can get Civic Si axles from HASport that work as well for a fraction of the price.
Old Oct 8, 2003
StLVtec's Avatar
StLVtec is an unknown quantity at this point
I got rsx axels and had them custom them on there, my shop used there guy at a machine shop to do it. Ive been waiting 6 weeks today so far. Like nobottle sadi there is a lot of little basic stuff that needs to be ordered.
Old Oct 8, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
what about the radiator? i hear you need a new one for a SI or better. tac on another $400....
Old Oct 8, 2003
civic-king's Avatar
check this out....
http://www.hondawerx.com/kseriesswapparts.htm
Old Oct 8, 2003
blue87's Avatar
blue87 is an unknown quantity at this point
That's a crazy swap yoo.... but keep everybody posted on how it's running afterwards...my friend did a swap not to long ago. It took him about a week. He put in a type-r motor and all the necessary gizmos. It all depends on the shop. They might have other cars to work on as well
Old Oct 8, 2003
Explosivo's Avatar
The dog told me to do it
Explosivo is an unknown quantity at this point
Do you loose your ac with the swap? I remember a while back reading that hella long thread with the first k20 swap and I seem to remember that he lost his ac...
Old Oct 8, 2003
RSXtypeIvtec's Avatar
Su Mo
no you do not need to lose your a/c now...
Old Oct 8, 2003
StLVtec's Avatar
No yo keep ac just nedd hoses and lines from 02 si. I just had to order si hubs to work with the rsx axles. Should hopefully be done next week
Old Oct 8, 2003
mcwoowoo's Avatar
i think the shop was able to get all the parts form junk yard, execpt for the radiator and a special auto->stick bracket.
but so far they haven't told me how much all these parts cost yet.
i only know that the labor will be 1700....
Old Oct 8, 2003
CivicSouldjaEX's Avatar
Import Builders in Fullerton, CA did htowncivics swap and they did a lot of custom stuff, I remember them saying they used GSR axles with custom ends. You can e-mail them questions through their site.
Old Oct 8, 2003
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
it shoulldnt take more than 4 days but can be done in a weekend with all the parts and the given the shop knows what its doin
Old Oct 8, 2003
mcwoowoo's Avatar
thanks for the tip,
i'll keep you guys updated ~
