How long should engine swap take?
I left my car at a shop in San Jose,CA called BlackTrax to do my K20A2 swap. I wonder if any of you know how long should this kind of swap take?
They started on last friday and when i called them this morning, they told me that they were working on the steering lines and stuff and they haven't got to putting the engine in yet.
BTW, i'm doing the hardest swap ever (i think) because my civic is a LX auto tran, and i'm converting it into stick shift and swaping the engine. Don't know when will this be done.........
oh ****.. that's a big *** swap.. lol an lx auto to a stick k20a2... nice tho.. i just felt like complimenting.. i dont know **** about swaps..
HISPAnIC CAUSIn PAnIC
i dont think its all that much harder to do just because its a auto even if your civic is a stick you still need to swap the tranny. my civic is a auto and i will consider doing a swap in a year or 2.
i dunno about engine swaps, but it seems to me as if all shops, even normal body repair shops or wutever take their time wen doing anything. either because they want to be careful, or sometimes just to charge more money or sumthin. speed image in san jose (never go here, bad plaec imo i only went ehre to buy light bulbs) told my friend it wud take 1-2 hours to install his intake, my friend and i instaled it in like 30 minutes.
i dont kno how engine swapping goes, but i bet if they realyl wanted to finish it quickly, they cud intsall it a lot faster than it will really take them if they realyl spent time on it working hard and crap. but i guess its better to go slow and make sure every thing is right, better safe than sorry.
from what i know, usually it takes a week or 2 depending on the shop. I've known shops that swapped in a b16 into a older gen civic over night ( 2 days total). I think the k20a2 swap may take up to 2 weeks...give them time man...don't rush the shop, let them take as long as needed...this is your life on the line here, don't take it too lightly. They do a good job, u're life will be secure, and u'll have a kickass car too...if u rush em, they much do a iffy job, and you might find urself in an accident in the near future. Good luck man!
Originally posted by Jodster
Well if they know what they are doing it should only take them a couple of weeks. There is alot of wiring to do. Not to mention the Key Code problems.
hasport suppose to have wiring harrness set for k20 swap, but somehow they haven't put it on their website yet.
Key Code is very easy to fix, i just order the Hondata ECU flash, they will clear and reset the key code.
here's a list of parts i've put in for the swap so far
K20A2 engine
DC 4-2-1 header
Injen SRI
Hondata
Hasport engine mounts
Custome dual exhaust
5zigen Copse 17' w/ yokohama es100 215/45/17
CF hood
how fast can my car go with this kind of setup?
K20A2 engine
DC 4-2-1 header
Injen SRI
Hondata
CF hood
Originally posted by kafyn722
quick question.. how much does all that cost. just the k20 swap is all i want.. how much?!?!
so if i'm only doing the engine swap, the total is about 7000
i'll keep you guys informed about my swap, if you have any questions regarding the details, try me. i might be able to answer them. or i'll ask the shop for you guys
-good luck
-good luck
my swap took about 2 months to do. There was a lot of little stuff that you dont even think of when you are doing it that come up and hold you back. I know it took HASport a weekend to do the swap, and that was from auto to stick...but they knew what they were doing, and they had a junk yard right accross the street from them. Good luck with your swap, question...why did you get the short header?...you might get like 2 whp out of it. In some cases, it has been proven to actually take away hp. Dont ask me how, i just read the dyno charts. Are you doing the 5-lug conversion? If not, make sure to get 2002 Civic Si axles, i tried the GSR ones, they dont work. Keep us updated.
YoUnG N SuXsExFul
ur getting ur car done at blacktrax? i got a quote from them and they wanted 4500 for the type s eninge and 1600 for labor! that didn't even include the motor mounts! well..keep us updated..i wanna see if black trax does a good job.
my engine didn't come with a airbox, so i thought might as well get a short ram.
and my car will still be 4 lugz, but i'm not sure which axles they will be using though.
when i went to them, they asked me to find most of the parts for them. so in my case, i ordered most of the big parts and have them shipped to blacktrax, and they took care of the small parts (steering pump, axles and stuff)
mine didnt come with an air box either...so i got a CAI, its the best with other mods like Hondata, TODA, and so on.
If you are keeping the 4-lug like what i did, the ONLY axles that work are the 2002 Civic Si axles. From dealer they are about 2 grand...yes really, 2 grand. But, you can get Civic Si axles from HASport that work as well for a fraction of the price.
I got rsx axels and had them custom them on there, my shop used there guy at a machine shop to do it. Ive been waiting 6 weeks today so far. Like nobottle sadi there is a lot of little basic stuff that needs to be ordered.
check this out....
http://www.hondawerx.com/kseriesswapparts.htm
That's a crazy swap yoo.... but keep everybody posted on how it's running afterwards...my friend did a swap not to long ago. It took him about a week. He put in a type-r motor and all the necessary gizmos. It all depends on the shop. They might have other cars to work on as well
The dog told me to do it
Do you loose your ac with the swap? I remember a while back reading that hella long thread with the first k20 swap and I seem to remember that he lost his ac...
i think the shop was able to get all the parts form junk yard, execpt for the radiator and a special auto->stick bracket.
but so far they haven't told me how much all these parts cost yet.
i only know that the labor will be 1700....
Import Builders in Fullerton, CA did htowncivics swap and they did a lot of custom stuff, I remember them saying they used GSR axles with custom ends. You can e-mail them questions through their site.
i'll keep you guys updated ~
