What I consider the perfect drop of a clean ride.
Old Oct 7, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Wallpapers are very possible.
Old Oct 7, 2003
All Eyes On Z
Old Oct 7, 2003
NeonImpact's Avatar
Forum Sponsor
yea man i totally agree..
that truck is very clean and just set at the right height adjustment..
hats off to the owner..
j/k man, looks real nice!
keep it up!!
Old Oct 7, 2003
All Eyes On Z
Need to retake this one some time.
Old Oct 7, 2003
All Eyes On Z
keep it up!!
I'm eager to slam a truck one day.
Thanks.
Old Oct 7, 2003
Mr.Modify's Avatar
what kinda suspension setup?
Old Oct 7, 2003
JayFReaZy's Avatar
nice drop man . What kinda springs, how many inches, and are you rollin on stock shocks?
Old Oct 7, 2003
Drnknmnky13's Avatar
I personally feel the back is just a tad too low. But thats just my opinion. That car is fantastically clean though..shiny shiny. Good job.
Old Oct 7, 2003
civic01vtec's Avatar
nice drop, looks real good.......i'm dropping mine this winter with bags though......i should be able to lay body.
Old Oct 7, 2003
civicvtec1ps's Avatar
Search and Learn
gc sleeved coilovers
Old Oct 7, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
That looks soo clean man....EBP Owns once again...
btw, i think you should black out your headlights..that would be tight.
Old Oct 7, 2003
All Eyes On Z
If the pictures were larger you might change your mind, but unfortunately they are.
The distance from the fender lip to the center hub in inches is:
Rear: 11 1/4
Front: 11 3/4
The rear is a tad low but you really can't tell for a couple of reasons. In the larger pictures, I'm convinced that the front looks lower than the rear but it's REALLY hard to tell because the rear wheel well doesn't arch over the tire like the front. The rear fender lips are are also angled inward towards the well. In most cases you don't see it as it blends in with the rear tire on dark colored cars in some pics. Depending on the angle or light, it can look too high or too low. If I measured the rear from the outer body (before the lip curves in) then the height would probably be considered perfectly even.
In the end, an evened out ride front to back looks best IMO. I can't go any lower in the front though and I don't plan to. This is the ride height I want to keep on 15s w/205-55 tires.
Old Oct 7, 2003
All Eyes On Z
I'm actually thinking about going back to stock headlights or just getting amber signal bulbs. Dunno. I'm done with modifying headlights. I've redone mine too many times. Not that I was bad at it - accidents suck.
Old Oct 7, 2003
Vinh's Avatar
oem look ownz !!!!
Old Oct 8, 2003
Jodster's Avatar
Post Whore General
Nice man. Clean
Old Oct 8, 2003
All Eyes On Z
Originally posted by Vinh
oem look ownz !!!!
Some say stock sucks.
I dunno what they were thinking.
Still, to each his own, though.
Old Oct 8, 2003
All Eyes On Z
Originally posted by Jodster
Nice man. Clean
You know it. Thanks.
Old Oct 8, 2003
Vinh's Avatar
stock doesn't suck at all....i like
Old Oct 8, 2003
Hawk's Avatar
You boost, I-VTEC
16" copper/bronze rims would own on a blue car with a drop like that imho.
Old Oct 8, 2003
XxSoVeReiGNxX's Avatar
to me, the perfect drop is when the edge of the fenderwell is the same distance all around from the wheel/rim's lip. Although rim tucking looks awesome, I don't like the camber usually associated with it (especially the rear wheels).
That's car looks good though
Old Oct 8, 2003
GreenNVicious's Avatar
Newbie
Thanks.
hmmm........
Old Oct 8, 2003
All Eyes On Z
I have a camber kit in the rear and you couldn't stick a baby's finger between the tire/fender lip. It's considerably a lot more positive than it is without a camber kit but if it was any more positive the tires would rub. It is as positive as it can go in the rear but overall it's still negative. I like some negative camber given how I like to drive my car, and it's set perfectly for my needs.
Okay, again... the height is evened out all around. Here are cropped picture of what the wheels look to the fender wells in the second picture.
Rear:
Old Oct 8, 2003
All Eyes On Z
Front.
There is only a 1/2 an inch difference between the front and the rear, and that's something you can't really see given the rear fender lip. Like I said, if the rear fender didn't curve inward like the front, then it would be perfectly even. I did my measurements.
It was actually a lot lower in the rear before, but I just thought I'd lower the front more. (Can't go any lower.) Now it's a lot more even.
Like my sig says... "Even out your ride height."
Old Oct 8, 2003
All Eyes On Z
Here's an idea of what my rear camber looks like.
Old Oct 8, 2003
All Eyes On Z
Originally posted by GreenNVicious
hmmm........
Go for it. Your truck probably has the potential to run circles around Civics as well as run over a line of them.
Old Oct 8, 2003
KeNsHiN's Avatar
LEVA
lovin' it! did you just wax it??
Old Oct 8, 2003
skyblue's Avatar
the heart can see::what the eyes cannot
skyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud ofskyblue has much to be proud of
I like it a lot...looks real nice
Old Oct 8, 2003
EviLMyStS's Avatar
All show!!!
Nice are you running stock shocks ?
Old Oct 8, 2003
All Eyes On Z
I waxed it a few days ago. Those pics were taken the week before. I take good care of my exterior.
Old Oct 8, 2003
All Eyes On Z
Currently yeah. I don't plan on having the GCs on for much longer. I've been on them for nearly a year now and it's time for something better.
