NGK plugs revived my ride!
As alot of you know, my car has a huge amount of problems. The most annoying thing was the engine rattle and sluggishness. I finally ordered some new plugs to replace the old ones with carbon all over them (only 17K miles old). Not wanting to get platinum for $12 each, I tried NGK iridium IX for half the price. It did seem to help with the engine noise, and acceleration felt better as well. Before it would really struggle and felt like it didn't want to go. Also I noticed a few of the plugs weren't even that tight when I took them out. Maybe that caused problems as well.
I also changed the air filter and my mpg without the new plugs was 24!! yay it's going back up. We'll see if the plugs helped any later.
Sorry about the long post, but maybe some will find this info useful. Needless to say, the civic and I had some fun tonight driving around town.
A descendant of 2k1civic.com
Very useful .. I'm looking to get some new plugs soon. . After reading your post about them carboning up after 17k, I decided that it was time to replace my plugs before winter since they have 38,000 on them.
Did you buy them online?
If so do you have a link?
Check the plugs first. If they don't have problems, just leave them in. The stock platinums are supposed to be good for a long time, and I only felt a gain because my old ones were messed up. The NGK iridiums are cheap at only $6-7 per plug. Go to sparkplugs.com and do a vehicle search. They have excellent response time and service.
this is the cheapest website i can find so far http://www.ngkiridium.com/
let me know where else is cheaper........... i want one too..........i want to try to replace my NGK Laser Platinum ...... allready 20000's miles ...... engine rattle and sluggish too
is Iridium better than Laser Platinum????
Thanks
Thanks
My plugs were mostly black, instead of the brownish color they're supposed to be. I found that they were fairly loose and easy to remove. Maybe this caused the problems.
Iridium has the most features out of all the plug types, but the ground electrode is still nickel. Thus, double platinums (which come stock and cost double what the iridiums do) will last longer.
i guess i dont really have to im just one of those paranoid people who cganges there oil every 2,500 miles on the dot and spark plugs every 5000 miles . i have 50000 miles on my car now and i want it to last a long time
As long as the plugs aren't fouled, they're still doing the job. Double platinum (stock) should last at least 80K miles, although my car has other probs that caused it.
And if you're gonna change your plugs every 5K, just get the copper plugs for $2 each.
will you make out with me
Originally posted by BREEZE
on the seach at spark plugs it says our engin is a l4... what is that i thougt it was a d16
-Keith
which one is better?? NGK V-Power or NGK Iridium IX ??????
"V-Power™
-Advanced V-groove center electrode provides optimum performance and fuel efficiency required by today's lean-burning engines.
-OEM-Approved Design
-V-Groove Design Enhances Ignitability
-More Complete Combustion and Lower Emissions
-Racer's Choice for Performance "
"Iridium IX
-Specially designed to meet the needs of serious enthusiasts, Iridium IX Spark Plugs offer outstanding acceleration, high fuel efficiency and long life. When you demand the most from your engine, rely on the proven performance of NGK Iridium IX Spark Plugs.
-NGK's new Iridium IX is the personification of these qualities and takes premium performance spark plugs to a new level. A level that is expected from the world leader in spark plugs."
thanks
"V-Power™
"Iridium IX
thanks
I think the only applications for our engine are the iridiums and double platinum. Iridium has more advantages, but double platinum (same as stock) lasts longer.
This list for 2002 EX from www.ngksparkplugs.com
1. V-Power Part# ZFR6F-11 Stock#4291 Gap=0.044
2. G-Power Platinum Part#ZFR6FGP Stock#7100 Gap=0.044
3. Laser Platinum Part#PZFR6F-11 Stock#3271 Gap=0.044
4. Iridium IX Part#ZFR6FIX-11 Stock#6441 Gap=0.044
Laser platinum comes stock, and the V or G power just looks like modified platinum plugs. The iridiums are the latest technology with the smallest center electrode. I would get iridiums (I did), but you probably won't notice any gain unless your old plugs are bad.
mine comes with ngk platinum ....... then i change it to ngk Laser Platinum ..... now, it's allready 20000 miles and i'm gonna change it next oil change (3000 miles more, i just change it today)
Should I go with the NGK Iridiums for my turbo and save money? Or should I spend the $46 on groupbuycenter.com and buy the Denso Ik20s?
I would go with the NGK iridiums since they're basically the same as IK20s. With a turbo, though, you may want to get a colder plug--and for that you have to get denso (not IK20 but a colder version). Check the turbo forum for what people use with a turbo. I've heard the NGKs are good for nitrous, though, so they should be fine with turbo.
Yeah I'm in the forums daily. The thing is, the IK20s are gapped .044 whcih is the correct distance for our engines. The IK22s are gapped even closer so I don't know if it would run as efficiently.
Proper gap is essential, so I would just get the NGK iridiums. Iridium is stronger than platinum so they should be fine with the turbo.
Thanks
Thanks
- Thought I'd say that to ecourage people to use that site even though it looks pretty plain and unfamiliar.
