Retard your ignition timing with this!
Don't know how many people have seen this. If you plan on running higher boost, look into retarding your ignition. Apexi Electronics has a universal application. Decent price too.
CLICK HERE
CLICK HERE
or u could get something that does all the fuel, all the igniton, all the vtec, and much more i think, all in one, emanage, for the same price as 2 of these, ITC, VAFC, or SAFC combined
i dont know how or who fixed it but a greddy dealer told my shop that it will work, my car is going back to the shop to have a new ecu put in and to see about getting the ignition from the emanage working
lemme know if the e-manage got taken care of on your ignition system, that would be awesome, i will eventually need a fuel system too
i have a lx ecu on a ex engine. lx for one doesnt control vtec, and the lx has a lower fuel cut off, round 115, and u cant go past that. i would prefer no fuel cut off but the ex ecu has like a 125 cut off which is better.
it will be a couple of weeks before i know how well the emanage ignition works.
Passin' You On 19's.....!
my02 dx cuts out at 128.... been there a few times.. wish it was like 160... lol.. but im fine with 128.. woint see it again any day soon.. and im only seeing 102 in 1/4 mile.. which is pretty much where i do my racing now... so im fine..LOL
how am I wrong? They have a REV limiter, which could act as a speed limiter once you hit 142.5 mph. Do the math on our gear ratios. There is nothing to prevent it from topping out, just lack of power.
ok it might depend on what year u have but by god mine has one bc ive hit it. round 115mph the car just wont go anywhere, and thisis in fourth, that means i still have all of 5th gear to top out.
the rev limiter engages as 7020rpms (i have a digital tach with peak hold capability). there is zero speed lilimiting, the ecu only prevents the engine from reving past that point
ive hit 7004 on the lx ecu are u sure the ex isnt higher, dont all the other generations the vtec motors rev higher than the novtec ones. i was hoping the ex ecu would have a higher rev limiter, my boost controller holds the highest stats attained so thats how i know i got to 7004
swear to god man. if you look even at the redline on the stock ex tach, it's 6800, same as the non-vtec, but the rev limiter kicks at 7020. I race at the track a lot and have hit the rev limiter god knows how many times, i've never passes 7020, that's the peak since i've hooked the thing up.
Back on topic lol....
I doubt you can use that thing on any of the new Honda engines. That's the problem. MSD universal apps don't work, so I doubt this would. I already posted that GReddy said that the new software update on the E-manage (v0.36) controls the new Honda ignition and has been working on all of the K series engines (same ignition). It's the fact that Honda's new ignition requires newer separate technology to control the ignition. GReddy had to make a fix to cater to all the k20's they sell kits for. The E-manage isn't exactly universal though... which I think makes the difference. To use it, it needs to know car manufacturer, airflow sensor type, and ignition type which basically creates a 3 piece code (X-XX)
First Part:
1 - 1 coil (distributor) 3 cyl
2 - 1 coil (distributor) 4 cyl
3 - 2 coil (wasted spark) 4 cyl
4 - 4 coil (coil on plug) 4 cyl
5 - 1 coil (distributor) 6 cyl
(only seems to be on the Toyota 1G-GTE inline 6)
6 - 3 coil (wasted spark) 6 cyl
7 - 6 coil (coil on plug) 6 cyl
8 - 8 coil (coil on plug) 8 cyl
A - RX-7 13B-REW
B - RX-7 13B or 13BT
C - RX-7 20B-REW
Second Part:
Honda Pressure
8A HN_PR-1
8B HN_PR-2
The code for ours would be 4-8-B. Right from there, the software automatically knows you drive a 4 cylinder Honda/Acura, with a MAP Sensor, and a DIS Single coil pack ignition. The software would then make the necessary changes to be able to control the ignition. Which is why GReddy can make a unit that can control multiple engines and not be universal. So that way if you have 2 different cars that have DIS ignitions, say one Honda and a Toyota, and they don't operate the same (which they don't), the E-manage software is able to distinguish between the two. This is why universal apps won't work.
CLIFF'S NOTES:
-Sorry For Raping thread
-Universal Apps can only work if all DIS Ignitions are identical in every car
-Honda's DIS ignition is different from any other DIS
-GReddy E-manage has the ability to tell the difference
-GReddy released software 2 weeks ago to fix it
First Part:
A - RX-7 13B-REW
C - RX-7 20B-REW
Second Part:
Honda Pressure
8A HN_PR-1
8B HN_PR-2
CLIFF'S NOTES:
Originally posted by MadWheel
ok that clears things up... So E-mange with the ignition harness and I'm all set?
