Venom in my A/F ?!?
Old Sep 23, 2003
JBDesign's Avatar
JBDesign is an unknown quantity at this point
Venom in my A/F ?!?
Has anyone used venom's a/f digital gauge. Does it just make a pretty light show or does it really work? If not then what a/f gauges do work?
Old Sep 24, 2003
JBDesign's Avatar
If no one has used it, then whats a brand that actually works
Old Sep 24, 2003
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
My autometer A/F actually works ots not digital it just has the little LED's that show you your ratio but its simple and works well
Old Sep 24, 2003
JBDesign's Avatar
i heard that the autometer just flashes around, does yours really work well, because i need one that works good.
Old Sep 24, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Your going to pay out the ***, you will need a wide band o2 sensor for any proper readings.
Old Sep 24, 2003
JBDesign's Avatar
So is it the gauge or the stock oxygen sensor that sucks?
Old Sep 24, 2003
xblkcivicx's Avatar
Most guages are not acurate, L ||||||R it's like your water temp guage C |||||| H well..that's not telling you much. Obviously if your really really lean yea, you will know but i've seen them hop all over the place. They are basicly as usefull as the autometer guage clock. It just fills a hole in your pod.
The stock oxygen sensor will not give you the reading you are looking for, it is not acurate and does not have a wide band. If you get your car dyno'd they use a wide band o2, which will give you an exact air/fuel ratio. The WB o2 should come with some type of meter or display. Digital or Analog. Depends on what your wallet looks like. But if you want to know exactly what is going on then that is the way to go. If you need a pod filler, get the 50 dollar A/F guage.
Old Sep 25, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
^^^ exactly right
Old Sep 27, 2003
JBDesign's Avatar
Alright, i'm going to look around see what i can find. thanks
Old Sep 27, 2003
clownprince's Avatar
Ricerus Maximus
pretty lights are cool though.
Old Sep 27, 2003
JBDesign's Avatar
Ha, not when your engine blows
h4ldol
Apr 24, 2017 08:16 PM
SiRocket
Feb 27, 2003 09:52 PM
Bartkat
Dec 4, 2002 02:19 PM
zetaR
Jun 12, 2002 05:28 PM
icey
May 21, 2002 12:52 AM
