Yet another "paint your headlights black" question...
Just Be
1) I have an 02 EX coupe, I heard you DO NOT need silicone to reseal--that our coupes have resealable.. well stuff. True? I went ahead and bought some anyway.
2) I bought regular flat black enamel paint. Not high temp... should i get a high temp one instead? The bottle (for the high temp) said 500degrees.. i couldnt imagine our headlights getting anywhere near 500 degrees, so i opted for the regular paint (due to the fact it was a buck less)
3) applying the paint -- did you guys sand it prior to spraying? I am thinking of using a 600 grit sand paper before applying the paint.
4) should i use primer? not necessary?
thanks!
i will be doing this tommorow morning, so quick answers are greatly appreciated!
thanks!
1) you can try using the stock sealant without applying new sealant. there is, however, the chance that you will get the black **** all over the place and there is the chance that it will **** your progress up, and there is the chance that your lights will fog. if youre careful though, you can do it proper and nothing will happen and you won't need new sealant. (I personally didn't use any new sealant the first time I cleared my headlights years ago, but due to an accident, those headlights are gone, bleh)
2) the only reason I could think that you would need high temp. is because the lights are near the engine area and could heat up a little more than maybe what your flat enamel could handle. however, I have heard that some people have used regular and had 0 problems. (if it was only a buck less tho, why didn't you just dish out one more buck? hmm..)
3) Topfuel told me long ago that I should sand it down to get rid of the chrome ish. so my advise is do that.
4) use primer- if you're going dark color, use dark primer, if you're going light color, go light primer.
hope it helps, good luck.
I used the stock sealant when putting them back together. Just reheat the parts in the oven until the goo is soft again and press back together. I have a sedan, but it should work for coupes, too.
Search and Learn
Originally posted by RedDragon333
i would use some extra seleant just in case as well i paid the extra dollar for the high temp but thats just my opinion
i didnt bother with primer or anything, didnt need it cuz its sealed .. and i used that black stuff thats allready on the light .. didn't add any fresh sealent or anything .. held just fine
mango!!! can you do a DIY or something? or not even, since it's not very hard, but at least take a couple pictures while the headlight assembly is separated. that's the one thing i want to see, since i don't know what the individual pieces are, and if i'll need to mask anything off. well, do it if you can; if you can't, that's cool, too.....
thanks
thanks
Search and Learn
thanks
thanks
a really dark gray, its called Dark Grey actually .. made by plasti koat .. i got it at pep boys ... i don't really like how the black looks ... its too flat .. doesnt look right to me
aight somebody help me out, i was about to do this project, but i have eternal blue.... i want to paint the heads blue.... is there a way i can get spray paint to match? or do i need to order from honda??? help quick, i wanna get this done
hey civictec.. what were those little black things in the first and second pics.. and what was the socket wrench for? do u need to remove some bolts to take the lens off the headlight?
edit:things=pics
edit:things=pics
Search and Learn
Originally posted by ferio
hey civictec.. what were those little black things in the first and second things.. and what was the socket wrench for? do u need to remove some bolts to take the lens off the headlight?
