what exhaust do you have in your Turbo'd civic?
Old Sep 17, 2003
civic_dxr's Avatar
civic_dxr is an unknown quantity at this point
i just wanna know for future reference
Old Sep 17, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
I have an obx catback
Old Sep 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
greddy evo
Old Sep 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
TCS
Old Sep 18, 2003
iamboo's Avatar
Retired - SoCal FI Mod
magnaflow muffler w/ custom 2.25" piping...
Old Sep 18, 2003
EnProceso's Avatar
i will be running a Tanabe r-spec
Old Sep 18, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
shitty 2.25" custom. Soon im installing my own SFturbo exhaust.... 3" mandrel bent with a 3" muffler.
Old Sep 18, 2003
andyman97's Avatar
Turbo Guru
2.5" machine bent w/ testpiipe
Old Sep 18, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
so id i already have 2.25 inch piping in my Tanabe, would a 3 inch work so much better for me to change it??
Old Sep 18, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
2.5 inch tsudo catback...need to get a testpipe made tho
Old Sep 19, 2003
Catalyst's Avatar
you dont need 3", but the better the turbo can exhale, the more power you make. Just remember, you dont have to worry about back pressure with a turbo.
Old Sep 19, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
I have the Thermal exhaust.
Old Sep 19, 2003
HondaLuver's Avatar
Its a celebration bitches!
high flow ceramic cat and 2.25 mendrel bent piping... going to get a test pipe soon. i don't have a turbo yet, im going to get a k20a swap in the near future
Old Sep 19, 2003
C2i0v0i1C's Avatar
SuperMODrizd
explain test pipe, is it the same thing as a flex pipe, if so then i understand, what is the point of a cat on turbo car, wont it get so hot that it melts the guts, if u want to pass emissions just adjust ur AF
Old Sep 19, 2003
PdchasinR6's Avatar
PdchasinR6 is an unknown quantity at this point
C2i0v0i1c...a test pipe is nothign more than exhaust pipe that goes where your cat used to be. your wrong about adjusting your A/F to pass emissions. if you dont have a catalyic converter on your car anymore then chemicals and by-products of combustion engines will pass though into the atmosphere which pollute the ozone etc etc etc....no matter how clean your car burns if you dont haev a cat you will not pass emissions. best bet is to buy a testpipe that bolts on and use that for 364 days out of the year and the day u go for emissions put the cat back on. even though a turbo car runs hotter after the first 12 inches that the air flows out of the turbo it is cooled down enough to pass through the cat which is much farther than 12 inches......my advice is to get rid of the cat anyhow b/c the faster you can get air moving out of your exhaust the faster your car will spool up. airflow is #1 when it comes to a turbo'd car.
Old Sep 19, 2003
PdchasinR6's Avatar
sorry for the double post but i forgot to list my exhaust.......custom 2.5" downpipe, 3" test-pipe and a 3" custom cat-back w/ an apexi n1 muffler
Old Sep 19, 2003
iamboo's Avatar
okay.. lets say we're drag racing... and you have a 3" exhaust...
would you really want to lose that much back pressure?? you want to keep the low end powerband high too... i realize that it only takes a couple feet to hit boost but still that low end in the beginning helps out a lot...
Old Sep 19, 2003
PdchasinR6's Avatar
sorry iamboo but your wrong about low end power being what gets you off the line....torque is what wins races especially a 1/4 mile race because torque is what gets you to that 60ft mark fast. having a free exhaust lets your turbo spool which creates torque quicker ending in a faster 60ft time (if you can keep the wheels from spinning). the problem is knowing what is the right setup for your car. i chose to keep a 2.5" downpipe and testpipe b/c hot air moves faster in small places and its helpful, by the time the air makes it to my 3" section it is expanding and needs that extra space....with any turbo'd system its been proven time and time again that no exhaust backpressure is the best........if you really want to see take your car the dyno and i bet that if you do a run with a full exhaust and then unbolt it at your testpipe/cat and dyno it again you'll pick up 15-20hp to the wheels. on my dsm i could run .2-.4 quicker times on the 1/4mile just by unbolting the exhaust.
Old Sep 19, 2003
Catalyst's Avatar
Lets make it simple to understand.....
The opening exhaust turbine is only a 2" opening, and it has the turbine physically blocking the exhaust path. So basically you have less than a 2" exhaust until after the turbo. Having this small of an exhaust passage creates just about the right amount of back pressure. You need back pressure to make low end torque, but you dont want as much for high end hp. But since the turbo is force feeding the engine, you dont have to worry about not having high end power
Old Sep 20, 2003
ImportRacer2123's Avatar
K20 Member
I have Apexi World Sport Cat-Back w/ 2.50" piping mandrel bent
Old Sep 22, 2003
Maverick's Avatar
Maverick is an unknown quantity at this point
I use the thermal catback exhaust with my turbo...anyone tell me where i can get one of these test pipes?
cloudguy
Apr 28, 2015 05:02 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
TrevH01
Nov 11, 2001 03:25 PM
colombianDXcivic
Nov 8, 2001 12:14 AM
HitlistCivic01
Oct 27, 2001 07:47 PM
