What to do if I am Rubbing?
Old Sep 16, 2003
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Ok, first i should say that i have 215/45/17 tires with motegi mr3 rims with a 40 mm offset i believe. I also dropped my car with the Neuspeed Sport Springs. I had no problems with rubbing until a few days ago when i finally put my ignalls rear camber kit on. I was told by members that with the setup i have, i will not rub. I do not get how i am rubbing. Could anyone provide any info about what they did to make the tires stop rubbing such as doing work on the fender or whatever. Ive searched and could not find anything so any help would be appreciated. thanks
Old Sep 16, 2003
HondaLuver's Avatar
Its a celebration bitches!
get negative camber again.. or smaller tires, i don't know who told you that... u will rub with those tires, you should have gotten 215/40 or 205/45 if you wanted it dropped like that
Old Sep 16, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
If you wanna roll your fenders, someone posted this link a couple of days ago: http://www.andrews.edu/~johnsonm/howto/rollfender.html
Old Sep 16, 2003
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
pound the lip in and it will not hit anymore i had the same problem with my Tains but i did it before i drove it the first time because i could see it would hit.
Old Sep 17, 2003
djmota's Avatar
exactly what he said. If you plan on rolling your fenders make sure you have some kind of touch up paint on hand.
Old Sep 17, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
I had the same problem on my 215/45/17 and Tein SS suspension. Heres what I ended up doing, went out the next day and 205/40/17 tires and then went to a body shop and had them cut a little out of my fender and roll it slightly, then I adjusted my back end a little lower and now have a little less than a 2 finger gap all the way around.
Rubbing sucked ***...It was because of my offset and camber kit also. I didnt want negative camber and couldnt go buy new rims so thats what I did.
Old Sep 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea i rolled my fenders my self.... its really easy... just bend the lip up.. i have no gap.. its down to my tire . and i have perfect camber... and 225/40/18's
Old Oct 5, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
...or just laser cut your fenders for like $50-$70 at mod shop (lots of custom truck auto shops do this) as it is a lot cleaner and doesn't stress the metal like folding could do and no need for touch up paint.
UltraHDGames
Jun 8, 2016 05:16 PM
cukaracha
Aug 29, 2015 05:27 PM
Pudnite
May 9, 2015 07:51 PM
2Hottie
Detailing
21
Jun 18, 2002 09:39 AM
soljahboy17
Apr 1, 2002 03:24 PM
