attn:people who have teins
Old Sep 14, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
im looking to buy the tein basic, but i would like to know how the ride is, is it too stiff, or is it okay? is the ride equivalent to the recommended settings for the tein ss? also, i know i need an aligment after i reach my desired height, ive heard people say do it right away, others say do it in a week after the springs settle, which is it? how much is an alignment? and next camber kit, spc is better than ingalls right? and where can i find spc for cheap, if that is the best one? Lastly, i need 2001 parts right? i have a 2002. some say all you need is the bearings, others say a whole bunch of other stuff too, exactly which parts do i need and what part numbers so this installs perfectly and i hear no squeaks and popping noises, sorry for all the questions, but plz answer all of them, thanks, btw, i searched and got mixed answers as i stated above.
Old Sep 14, 2003
civicvtec1ps's Avatar
Search and Learn
alignment. really depends on your local shops. call around.
i had 2002 ex. didnt need to buy any 01 bearing to put tein ss. had no problem using 02 stock suspension parts. you do not need alignment rightaway ,just drive around couple days and take it in for alignment.
tein isnt comfortable as stock suspension. stiffer than stock. no bounce, althogh you will feel once you hit bumps.
parts about 01 beaing crap. dont even need them but heres part numbers
you can order honda parts online, or at ur local dealer, make sure you tell them that the Hodna Part #.
01 Honda Bearing Part #: 51726-S5A-004 (make sure order 2 for FR, FL)
http://www.hondaautomotiveparts.com...s=51726-S5A-004
here ya go
Front:
369032 Part 9 (BEARING, FR. SHOCK ABSORBER MOUNT) $13.98 X 2
369034 Part 10 (MOUNT, R. FR.) $23.45 X 1
369034 Part 11 (MOUNT, L. FR.) $23.45 X 1
Rear:
36557 Part 1 (WASHER, SHOCK ABSORBER MOUNTING) $0.27 X 2
22692 Part 2 (COLLAR, SHOCK ABSORBER MOUNT (DUFFY STEEL PARTS) ) $0.45 X 2
369095 Part 8 (RUBBER, SHOCK ABSORBER MOUNTING) $4.74 X 2
369097 Part 9 (BASE, RR. SHOCK ABSORBER MOUNTING) $18.62 X 2
369099 Part 10 (AL, SHOCK ABSORBER MOUNTING) $3.80 X 2
369101 Part 11 (PLATE, SHOCK ABSORBER MOUNT) $1.79 X 2
369103 Part 12 (RUBBER, RR. SPRING MOUNTING) $9.71 X 2
369105 Part 13 (COVER, RR. DUST) $7.22 X 2
369109 Part 15 (PLATE, BUMP STOP) $2.15 X 2
__________________
you can still use 02 stock upper mounts , reuse bearings. i didnt have any problem with it
edit= PM danscreations for spc camber kit
Old Sep 15, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
yeh, u definitely needed that 01 bearing if you drive 02 model, cuz if you tried to put that 02 bearing on tein basic, once you jack up ur front wheel, then front units will come lose cuz that 02 bearing not fit right for tein, cuz the spring tension push out the 02 bearing, so only 01 bearing fit perfect to the tein basic or ss, if not then the prob. will come up....like noise when make turn, blah blah blah.....but if you dont wanna get 01 bearing, thats oky too, just make sure u DONT jack up ur front tire.
you will see when u get ur tein install...
Old Sep 15, 2003
sigauto's Avatar
sigauto is an unknown quantity at this point
Anyone have pics of the bearings?
Old Sep 15, 2003
mig's Avatar
mig
mig is an unknown quantity at this point
Back when I was researching Tein Basic, I emailed Tein and they said that the Basic's valving is similar to the recommended setting of the Tein SS. Personally, I think thats too 'soft' a setting. I drive around with my SS's on their firmest, and it feels about perfect. I can accelerate through a curve, and the suspension stays level and composed. This has to be my most worthwhile mod.
Yes, get the alignment after about a week of driving around. Just before you get the alignment, you'll want to get your tape measure and check all four corners. make sure your front drops match, and that your rears match. my rears are set about 1/2" higher.
I went with the Ingalls kit from Greg at Hondawerx.com. It was about $135 shipped(includes front and rear hardware). I got the poly bushing type. The Ingalls seemed well engineered and very rugged, so I felt comfortable with them.
Old Sep 15, 2003
so ingalls is better that spc? also would these tein basics last me a long time. i dont want the shocks blowing out any time soon, how long average would they last, i know like stock shocks would las aveerage like 12 years maybe, just a guess of course
Old Sep 15, 2003
MIT's Avatar
MIT
well, i guess tein last long for a couple years, as long as you dont slam it and dont abusive it, .......it come with 1yrs warranty from Tein!
Old Sep 16, 2003
K20me's Avatar
Hey I just installed my Tein Basics last week, it took a while but the result is everything I expected. The ride is stiff but not bouncy, andI did use the 01 bearing rings,better safe than sorry I guess cause it was kind of hard getting the front shocks on. Now I'm just waiting on my spc camber kit before I get my alignment done. Best mod on my car yet!
Old Sep 16, 2003
so whats better for camber kit, spc or ingalls? lol would teins last like 10 yrs if u dont really abuse them?
Old Sep 16, 2003
mig's Avatar
mig
I doubt one's better than the other. They're made out of the same steel and have the same adjustments. I would think Teins would last a good 3-5 years of abusive driving, so maybe twice that if normal driving. They're rebuildable, so you could always freshen them up if you notice declining performance.
Old Sep 16, 2003
Search and Learn
spc i told you already
Old Sep 16, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
get the SPC... the ingalls just isnt as beefy looking....
Old Sep 17, 2003
thanks guys
Old Sep 17, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
I have SPC with my Tein SS. Its just a camber kit, lol.
What do you mean Tein will only last for a couple years???????
GolNat
Nov 27, 2018 03:32 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
cukaracha
Aug 29, 2015 05:27 PM
EM_WON
Jul 22, 2015 06:49 PM
